    Default Zero Oil Pressure, no other indications
    I recently noticed that I have zero oil pressure. I have checked the oil many times and have good quantity. There are no other associated bells and whistles with the zero pressure indication. I plan on checking the sending unit but wondering why isnt there any other indication. Any suggestions?
    Thanks
    What year, miles and engine? Does it come up as you bring the RPM's up?
    1989 Pontiac Bonneville LE
    1995 Pontiac Bonneville SE
    1995 Chevrolet Suburban LS 1500 4x4
    2000 Pontiac Bonneville SSEi
    Legend unplugged's Avatar
    Sep 2006
    High Deserts of SoCal
    Yikes! Is the oil pressure / check engine light on? Most likely the ops, but I'd check it sooner than later.
    High Desert SoCal
    02 Honda Civic LX
    Need more vehicle info(year,make,model) if your gauge is working correctly the computer would kill the truck so no damage occurs. Is your truck overheating or knocking?
    Hypertech III, K&N, true dual
    285/75/16
    ___________________________
    Jason
    It is an 08 silverado 4wd crew cab with 39K on it. No other lights or warnings. Oil quantity is good, no leaks. No heating problems, no knocking or other noises. There was absolutely no guage response to rpm changes for a while until yesterday when it just broke zero and fluctuated a small amount before falling back below zero.
    murdog94's Avatar
    You are still under the powertrain warranty I would get it into the dealer ASAP.... hopefully it is just the sending unit...
    Mike
    Currently
    2011 F-150 Crew 4X4
  1. Low oil pressure (maybe)?
    By bigburb in forum Performance & Fuel
    Last: 01-19-2010, 03:44 PM
  2. Oil Pressure
    By Lightzz2k in forum Chevy C/K Truck Forum
    Last: 06-29-2009, 09:23 PM
  3. Oil Pressure changes
    By GiS in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 06-10-2009, 03:13 PM
  4. low oil pressure
    By jackofallammo in forum GM Powertrain
    Last: 04-13-2009, 09:36 AM
  5. oil pressure
    By caprice88 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 11-18-2007, 11:44 PM
