    Default error code P0446
    So last december this code popped up on my 2004 gmc sierra. turned out the EVAP vent solenoid was bad and it was replaced under my trucks warranty. My truck is out of warranty now and the same code popped back about a month ago. I called the dealership where i got it fixed and the solenoid was 1 year warranty so i brought it to the dealership for them to test it. They say the check engine light just turned off when i dropped it off (i think they cleared it and couldn't get the code to pop back up and didnt know what else to do) but they said they tested the solenoid and it was fine. so anyway i took it home and about a week later the code came back on.
    i did a search a found this:
    http://www.gmtruckclub.com/forum/showthread.php?t=18964
    So could my problem be the vent is clogged? The EVAP solenoid is brand new and supposedly working fine. It said the problem is caused by dust getting in there. Sense i got it fixed last december the truck hasnt seem any dirt roads or dust. All highway driving. Could the heavy usage of salt they use up here clog up the vent?
    I would still say that since it is up again take it to them and show it is back on. since it is the same code for what was fixed should be done free.
    David
    1960 Land Rover Series II 88
    2001 Pontiac Sunfire
    NRA Life Member
    They said even though its the same code it would only be covered if the EVAP solenoid was defective sense thats all they replaced last time. They also said when i brought it back they tested the solenoid and it was working fine.
    Its most likely the vent on top of the tank, I had mine replaced under that same code and that took care of it. It was like $100 bucks total for my shop to drop the tank and rplace it.
    Hypertech III, K&N, true dual
    285/75/16
    ___________________________
    Jason
  1. P0446 EVAP Code (check engine light)
    Last: 09-30-2011, 02:56 PM
  2. alarm code p0446
    By grubbs11 in forum Chevy Silverado Forum (GMC Sierra)
    Last: 03-29-2010, 12:55 PM
  3. P0446 Code i just dont understand
    By Prophet1990 in forum GM Powertrain
    Last: 02-06-2010, 05:14 PM
  4. '06 Colorado with a P0446 CEL code
    By Boxman7481 in forum General Chevy & GM Tech Questions
    Last: 07-22-2009, 07:15 PM
  5. engine light comes (code P0446)
    By 2003tahoew22's in forum GM Powertrain
    Last: 01-05-2008, 09:57 PM
