    Default should i change my solenoid, or the whole starter?
    seems like every week im fixing my truck.. time to sell?
    my truck has been starting bad on and off for the last year(basically since i bought it). it used to be everyonce in a while it sounded like a extra heavy drain on battery when trying to start, like the battery had low voltage(but it didnt). since then its gotten worse and worse to the point of now sometimes not starting at all. other times when i try go to start it it starts totally normal(very rare now).
    tuesday it wouldnt start at all, i heard the starter engage on the fly wheel once, then after that wouldnt do anything. left it for a couple hours, came back, and started just fine. now today when i wasnt at home it did the same thing. like the starter was totally disabled. tryed boosting, no change. pulled out my hitch and tapped the starter, it engaged but wouldnt turn over. pounded the starter with the hitch, started right up. my next stop was to Canadian tire to pick up a starter, i lucked out, it was on sale($114 for starter, $10 back when i bring in my old one, good price?) champion starter with a 3 year warrenty.
    My question is.. should i just go ahead and change the hole starter, or look for just the solenoid at another part store, i would guess saving myself $40-$50. i am on the right track right? it is my starter solenoid?
    thanks again guys.
    98 Silverado
    5.7 vortec
    14 bolt posi rear, with 373s
    3"body?1.5"susp.
    33" wild countrys
    tube steps, chrome kit, fenderflares,
    chrome diff plate, window flares,
    2-10"Alpine TypeE, Alpine 450watt V-Power.
    Legend unplugged's Avatar
    Sep 2006
    High Deserts of SoCal
    Could be the ignition switch. But a load test of the starter will tell you what you need to know. Most parts stores can test the solenoid/starter.
    High Desert SoCal
    02 Honda Civic LX
    murdog94's Avatar
    Ditto on taking it to the parts store.. and you might want to consider having it rebuilt.. I know that it is just cheaper for me to buy a rebuilt one from the parts store for my TBI.. It is $42 US for a rebuilt starter here and the cheapest place i found that rebuilds starters in my area charges $55.. So no brainer but i know up in canada prices can be often skewed a bit from ours.
    Mike
    Currently
    2011 F-150 Crew 4X4
    you need to load test battery
    do voltage drop tests on batt pos to starter and bat to engine grnd
    do a cranking amp test
    once you know all your circuits are ok replace or rebuild the starter
    GM TECH
    05 silverado shortbed
    A common overlooked problem that will give you a crappy battery charge and rob voltage when trying to start your vehicle is corroded battery wires. The blue clumpy corrosion can even creep inside the insulation of the wire if its been there long enough and will be very parasitic when trying to start.
    Hypertech III, K&N, true dual
    285/75/16
    ___________________________
    Jason
    changed the starter. $104. cdn for a rebuilt champion. works like a charm now. looks like it was the starter indeed.
  1. ABS solenoid replacemet ???
    By FireRed in forum Lifted & Offroad Suspension
    Last Post: 05-16-2010, 10:47 AM
  2. Pressure control solenoid??
    By BigBurbanator in forum GM Powertrain
    Last Post: 02-26-2010, 10:19 AM
  3. 1-2 Shift Solenoid
    By jnbascom in forum GM Powertrain
    Last Post: 12-03-2009, 06:10 PM
  4. any help with vent valve solenoid?
    By Nicholas23 in forum Performance & Fuel
    Last Post: 06-13-2009, 08:57 AM
