    Default 04 Tahoe Rear tail lights not working
    Whay do chevy trucks have so many wiring issues? What happened to simple?... Anyway, read other forums , etc. Some help, but didn't work. Everything was working, then 3rd brake light went out..$LED$. Replaced, no problem. worked. 24 hrs later noticed Rt Rr brake burned out and socket discolored, fog lights out and dash button doesn't engage. Rear tail lights don't come on when headlights are turned on. Checked wiring best I could , didn' notice any bad spots. Checked fuses- all ok , all front lights work: head, park, travel lights, signals, All ok.. Fog still look ok.None burned out. Rear lights all work (switched the signal bulb with tail lite to check this. Brake is diff. bulb), none burned out except the R-R brake . Replaced this brake light, works, but stays on/no blink when car is on, guess the socket needs to be replaced. But the big problem is the fog and Rear tail lights. Would replacing the brake socket help the brake blinker? what would fix the tail lights? Thanks for the help.
    Fory our taillights you said the socket is discolored, you need a new circuit board then, they run from 25-35 bucks at autozone, oreillys etc.....
    Hypertech III, K&N, true dual
    285/75/16
    ___________________________
    Jason
    Jr. Apprentice bjwelch76's Avatar
    May 2010
    Shreveport, Louisiana
    I had the same problem with my 01. Me and my best friend spent four hours chasing wires with an Ohm meter. In the end, out of desperation because we could not find a reason for them to be out, I changed the fuse under the hood even though the fuse was still good. It fixed it. I don't know, it just did.
    2001 Silverado 1500 Ex cab 2WD 4.8l 418RWHP
    double check all your fuses underhood and in dash
    check for burnt spots on your bulb contacts and the socket contacts.
    have you check for pwr at the fog light circuit?
    GM TECH
    05 silverado shortbed
    From Bulldawg. Guess I am responding correctly. Thanks for the suggestions. 1. Replaced socket in R R brake,...light still stays on. 2. Where and WHAT is the circuit board, I keep reading about? 3. I'll try the suggestion with the fuses. ...If after 2 and 3 and the rear tail lights still don't come on when headlights are on, guess I'll give up. THX ya'll
    Hi, I 'm having the same problems. Where under the hood are those fuses? The dash fuses are fine.
    Thanks!
    pk
    Quote Originally Posted by Loggerhead Mike View Post
  1. 82 K10 Tail and Reverse Lights Not Working!
    By ahobson1 in forum Chevy C/K Truck Forum
    Last: 06-20-2010, 08:08 PM
  2. Tail lights not working
    By carlsauction in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 05-28-2010, 08:39 PM
  3. Replies: 4
    Last: 09-03-2009, 03:52 PM
  4. Rear tail lights not working
    By floutlaws in forum General Chevy & GM Tech Questions
    Last: 08-22-2009, 10:21 AM
  5. Trading My Stock Tail Lights for Euro Tail Lights
    By ippielb in forum Chevy Truck Accessories
    Last: 07-10-2009, 11:50 AM
