    Default Spark plug questions
    I am getting ready to change my spark plugs and in my owners manual it calls for ACDelco 41-974 or NGK PZTR5A15.I decided to go with the NGK plugs and had my friend bring some home from work...He brought NGK tr55...Does anyone know if they just changed the part # for them or if they are the wrong ones?Has anyone used these plugs before?Also they need to be gapped at .40 correct?Does anyone know what the torque specs are for plugs on a 03 silverado 5.3?Thanks
    03 Chevy Silverado 1500 ext cab Z-71
    79 AMC Spirit GT
    77 Olds cutlass supreme
    Master Mechanic Dr_Zero's Avatar
    Mar 2006
    Sunny Florida
    Quote Originally Posted by Z-71 View Post
    NGK (7862) PZTR5A-15 Laser Platinum Spark Plug
    NGK Laser Platinum Spark Plug is manufactured to provide high ignitability. It is constructed from durable material. It features platinum disc welded to backside of ground electrode provides long life and the trivalent metal plating provides superior anti-corrosion, anti-seizing properties. This Spark plug surface ensures slow wear rate providing stable idle, superior anti fouling, improved fuel efficiency and lower emissions.
    NGK (3951) TR55 V-Power
    NGK V-Power Spark Plug is designed to improve ignitability even in lean burn conditions and the performance of the vehicle. It is constructed from durable material that is corrosion and abrasion resistant. This Spark plug is highly durable against electrical and chemical wear. It features increased fuel economy and lower emissions. This Spark plug lowers ignition system voltage requirements and ensures longevity.
    The second is a less expensive plug and does not look to be platinum.
    If you want some inexpensive platinum plugs that work well check out
    http://shop.advanceautoparts.com/web..._1154311765___
    My trucks!
    1996 GMC Suburban SLT
    1997 GMC Yukon SLT
    I like AC Delco plugs myself. Yes, gaps should be .040". Best way to tighten them is an eighth to quarter turn past finger tight. Don't forget a little copper Never Seize on the threads.
    Whatever you do, don't install Bosch +4
    Master Mechanic bigdaddy77084's Avatar
    Jan 2010
    Houston, Texas, United States
    Im a ac delco fan myself, never had any plug last as long.
    I gap mine at 30-35 that way as the the plug burns The gap gets
    bigger. No need to regap later..Think about it as the electrode burns
    down your gap gets bigger.
    95 tahoe 2dr 4x4 200,000+ miles
    Okay thanks guys!I guess I will send these plugs back and get either the correct Delco or NGK plugs so they are at least platinum.
    79 AMC Spirit GT
  1. Spark Plug?
    By Chevyman224 in forum Performance & Fuel
    Last Post: 11-05-2009, 06:15 PM
  2. What spark plug to use?
    By partsman in forum Chevy C/K Truck Forum
    Last Post: 03-09-2009, 12:58 AM
  3. Spark Plug ??
    By Blakjax98 in forum General Chevy & GM Tech Questions
    Last Post: 01-04-2009, 10:58 AM
  4. General spark plug comments and questions
    By Springthing in forum General Chevy & GM Tech Questions
    Last Post: 01-04-2009, 10:54 AM
  5. Spark Plug Questions / Recommendations?
    By MWright936 in forum Performance & Fuel
    Last Post: 11-02-2008, 11:04 PM
