    Question help after headlight mod
    Hi guys,
    I just did the mod that makes your low beams stay on with the high beams. My questions is, I have 100w bulbs in my high beams and low beams, is this too much wattage? Or will the wiring be ok? thanks
    or should i back the low beams down to 55w?
    I would think that is fine. If the wiring has handled it now it still will with them both on as they will still be running on seperate wires. If you pigtailed them into one set of wires you might have an issue.
    David
    1960 Land Rover Series II 88
    2001 Pontiac Sunfire
    NRA Life Member
    Depends on which mod you did. You should have a separate relay for high beams, and one for low beams. Also, make sure your grounds are as big as your supply wires.
    If you're running 100wX4, I think that will be a big load on the system...
    Kurt
    Trenton, FL.
    http://www.flaguns.com
    2010 Chev Silverado LT, 5.3L V8, 6 Spd Auto, 4x4, Z71, HD Cooling, 3.42 Locking Rear End, Rough Country Leveling Kit, Smittybilt Nerfs, Sprayed Bedliner, DDM HIDs, LEDs
  1. headlight help
    By zackyv55146 in forum Chevy Truck Accessories
    Last: 01-07-2010, 01:30 AM
  2. Headlight help
    By lsutoms in forum Chevy Truck Accessories
    Last: 12-23-2009, 11:15 PM
  3. NBS Headlight Kit
    By CornhuskerChevy in forum Chevy Truck Accessories
    Last: 08-30-2009, 08:26 PM
  4. Headlight Bulbs
    By Cav_spartan in forum General Chevy & GM Tech Questions
    Last: 06-24-2009, 08:05 PM
  5. FS: Headlight
    By invader in forum General Classifieds
    Last: 12-17-2007, 05:29 PM
