Results 1 to 10 of 12
Thread: rodent nests
    Default rodent nests
    Since my 2002 Silverado is used for towing exclusively, it sits for months at times. Last year I happened to open the hood and found a nest at the firewall which was a mess with the insulation, branches,leaves,etc. Is there some repelant item I can use.
    Fguros
    Use poisen slowly they will start dissapearing.
    2009 Silverado LT 1500 2wd Crew Cab
    Imperial Blue, Ebony Interior 4.8L V8 4spd
    Rear axle 3.23 ratio
    What poison is used to eliminate nests?
    Pellets. You could find them at a hardware store.
    Master Mechanic bigdaddy77084's Avatar
    Jan 2010
    Houston, Texas, United States
    A poison is gonna kill them 4 sure..If your cat/dog gets one that has the poison in its system, good bye pet. Also they are gonna crawl up somewhere and die, leaving a rotten stinking body..just my .02...Good Luck..
    95 tahoe 2dr 4x4 200,000+ miles
    Rodents are a pain, and it doesn't have to be just vehicles that sit for months. My 97 pickup had a nest in the air filter box, I was driving it everyday at the time.
    Dryer sheets are popular in the RV crowd for keeping mice out, apparently they work quite well.
    Jan 2010
    I was told mothballs..But I have a hard time cutting them off..
    Master Mechanic rustyk2's Avatar
    Mar 2010
    South Carolina
    You just gotta use very small scissors.
    Dana South Carolina
    1986 V20 Suburban
    1988 V20 Suburban
    1995 Camaro convertable
    2003 Trailblazer LT
    :sign0196::wink2:
    Quote Originally Posted by bigdaddy77084 View Post
    good one
    David
    1960 Land Rover Series II 88
    2001 Pontiac Sunfire
    NRA Life Member
    murdog94's Avatar
    You also have to be really fast....
    I use mothballs to keep out mice in my sleds during the summer, and the squrrels and other rodents out of boat during the winter.. they work great. And if the truck is sitting all you need to do is place a couple on the top of each tire, and a few under the truck.. Dont worry about putting any inside since it will stink and placed properly will keep them far far away from your truck.
    Mike
    Currently
    2011 F-150 Crew 4X4
