GM Truck Club
Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. #11
    Jr. Apprentice
    May 2010
    The Desert
    Default Ignition switch?
    Quote Originally Posted by Scarbreaux View Post
    I can stop at a stop light, apply gas to take off and it will die as though out of gas. Most often it happens while traveling at a higher rate of speed. I can be going down the I-49 and have it shut off at 75mph. If you try to start it immediately it will not. It sounds as though it is out of gas. However I can wait 15-20 seconds and it will start right up. At times I can go 40 miles before it happens again and sometimes I don't make it 4 miles. Previously changing the fuel filter has been a temporary fix (4-6months). However this time is different, within 2 days it is happening again.
    And yes I do get all of my lights...immediately, even when it wont start the lights will still be on.
    I am offering this info, but don't know if it applies to these newer trucks. Hopefully someone on the forum will correct me if it is impossible. I had an '86 truck that experienced a similar problem. It would stop running, usually at the worse time. It turned out to be the ignition switch.
    '99 Silverado 1500,Z71,ext cab,5.3L,50 series Flowmaster, 3" exhaust.
  2. #12
    Jr. Apprentice ecombe's Avatar
    Jul 2006
    River Ridge, LA
    Scarbreaux,
    Your symptoms sound very similar to the ones we experienced on our 02 Flex Fuel Suburban prior to our fuel pump failing. You didn't mention how many miles on the vehicle (or I missed this in the thread). Our fuel pump died at around 79,000 miles. A month or 2 before it died it started killing intermittently and/or run rough briefly, but would always go back to acting normal. Until one day it continually died after only a few minutes of running between stops. Took me about 45 minutes to drive it 2 miles to the shop. I do most of my own maintenance, but dropping the fuel tank was something I didn't have the time to do back when the fuel pump failed.
    As far as the service engine light going on and off - we experienced that also. The intermittent codes (I don't remember their exact number at this time) indicated problems with the fuel injectors - due to intermittent insufficient fuel supply. Once the fuel pump was changed, the service engine light codes went away and fuel supply has been great since (about 35,000 miles).
    Hope this helps.
    05 Suburban LT
    02 Suburban LT
    94 Jeep Cherokee
  3. #13
    I agree with the fuel pump being the issue. I had a stalling problem that would happen at random times on my '02 Burb. Sometimes would start right up and sometimes would take ten minutes to refire. after about six weeks of chasing the problem I put in a new fuel pump assembly and Wallah! Problem has never returned.
  4. #14
    Sr. Apprentice
    Jul 2009
    Weatherford, TX
    Quote Originally Posted by Red View Post
    I've had the exact same result. Ignition switch issues caused by my "too heavy" set of keys.
    '95 1/2 ton Suburban 4wd 350, 140K, w/ tornado and k&n filter | everything else stock
    '89 1/2 ton Suburban 2wd 350, 200+K, completely stock except 31 x10.50 tires & 40 series flowmaster
    '85 1/2 ton Suburban 2wd 350, 250+K, burnt valve :lol: , edelbrock 50 carb, comp cam, silvolite pistons, HiPerf distributor, 18" glasspacks
  5. #15
    Sr. Apprentice
    Jan 2009
    West By God Virginia!
    I agree with the fuel pump diagnosis. It sounds like what happened in my '99
    I have no convictions ... I blow with the wind, and the prevailing wind happens to be from Vichy
    The Herd:
    FoxyCleopatra '99 Chevy Suburban 159K mi
    Rudolf 86 Mercedes Benz 300SDL - 305+K mi
    Fritzie 84 BMW 528e 234k mi
    Jenny '74 Jeep CJ5 23000 mi Factory plow package
    Former GM cars:
    1957 Nomad 283 4bbl rams horns,glasspacks disc brakes White over red
    1963 Corvair Monza 102hp convertible Aqua
    1963 Catalina 2dr 421 4bbl Navy/light blue
    1967 GTO 400 HO his/hers convertible White over red
    1971 Buick GS 455 Conv Black over red
    1977 Impala 305 2bbl Red/red
    1982 Celebrity Silver /blue 2.8 six
    1988 Corsica Red/red 2.8 six
    1996 Impala SS BBB/ gray LT1
  6. #16
    I'm offering this info, it may or may apply but sounds similar to the issue my dad had with his 2000 C3500, it would die going 75 on the highway, finally it would not restart and had to be towed, it turned out to be the crankshaft position sensor
    2003 Chevy Suburban LT 1500 4wd-All factory opts except autoride, sunroof, and captains added Bullbar, strobe light in widshield, strobes in rear windows, CB radio, Police Scanner, police horn, off-road lamps. Adding a 3in lift and larger tires
Similar Threads
  1. Like my mother always said Buy the best and cry once
    By Dr Len in forum Performance & Fuel
    Last: 05-26-2010, 07:28 PM
  2. 2010 GMC Terrain Helps GM Woo Moms - Mother Proof
    By ChevyFan in forum Chevy Traverse Forum (GMC Acadia, Buick Enclave)
    Last: 09-24-2009, 12:20 PM
  3. Replies: 5
    Last: 08-22-2009, 05:39 PM
  4. Third time is a mother _ _ _ _ _ _ _ charm!!!
    By Darknesss23 in forum The Coffee Shop ~ Chit Chat
    Last: 08-03-2009, 09:17 AM
  5. Never Lie To Your Mother (old but good)
    By Sooner in forum Photo & Video Gallery
    Last: 02-18-2008, 04:11 PM
