GM Truck Club
Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 21
  1. #11
    Sr. Mechanic
    kburb's Avatar
    May 2010
    Blythewood SC
    Quote Originally Posted by vncj96 View Post
    backpressure issue, how big of pipes did you start with and what did you step up to. If you have too big of diameter the exhaust wont flow as well and this could be the cause for the extra moisture in your exhaust as it is cooling more because it doesnt have the same velocity in the smaller diameter pipe
    What did the truck have stock for exhaust?
    When you removed the cats did you add dual?
    The stock manifold did not flow as well as the longtubes and if the primaries are to large you might not have enough backpressure.
    91 Suburban
    D44/14BFF w/Disc conv - Yukon 4:88's - Yukon Grizzly Lockers F/R -13" lift - DIY4x Shackle Flip - 37 ATZ on 18 MT Classics - Doug Thorley headers - Magnaflow - Holley Pro Jection Intake - Ultimate TBI mods - Hydroboost Brake Conversion - Hysteer-X Over Conversion.
    (Coming up - Fuel Injected 383 Stroker - Divorced NP205 - D60 - 40" tires)
  2. #12
    I had true dual exhaust with cats for over a year now. I cut my cats off in January, and had a LOT of exhaust leaks, and still had no problems. I installed my long tube headers, and i had to cut my o2 sensor wires to relocate them, unless i really buggered up my o2 sensors, it might be a back pressure issue, how can i test it to see if it is a back pressure problem?
    www.youtube.com/ippielb
    2002 Chevrolet Silverado 1500 z71 1985 Chevrolet Silverado k10 2006 Chevrolet Silverado 2500hd 6.6l LLY Duramax
    6.5" BDS Suspension Lift Edelbrock Carb & Polished Intake Manifold & Valve Covers NAPC Race Transmission & NAPC Built Transfer Case
    EFI Live Comp Cam and Valvetrain Snow Performance Methanol Injection
    35" Toyo Open Country Mud Terrain on 18" Ion Alloy 179's Headman Long Tube Headers and True Dual Exhaust FASS 150gph Titanium Series Pump
    AirAid Cold Air Intake with K&N Dry Filter & AirAid PowerAid Throttle Body Spacer 2" Suspension Lift 33x12.50r15 Tires EFI Live & AFE Stage 2 Intake
    Pacesetter Long Tube Headers with Cats Gone True Dual Exhaust FlowPro 3.73 Gears Yukon Grizzly Locker with Mag-Hytec Cover & Traction Bars
    NGK Iridium Tips & MSD Ignition Plug Wires Baja Spare Tire Holder 33x13.5 Hankook rt03 18" XD Rims
    Innovate LC-1 Wideband o2 Sensor x2 HID's all around LED taillights and 3rd brake light
    BDS Dual Steering Stabilizers Pioneer Double-DIN Touchscreen Navigation with Two 10" Subs under rear seat
    Electric Fan Autometer Pressure, Boost, and Pyro Gauges
    4.56 Gears Airlift Air Bag Suspension
  3. #13
    I have two new front o2 sensors coming to the shop this week, i think i may have a fuel pressure problem, it may be my fuel pressure regulator, because when my truck gets in high RPM ranges there's visible smoke from the exhaust, and it smells a lot more then with just cats off. I'm thinking i'm putting a lot of the fuel out the ass end of my truck.
  4. #14
    I found out it only smokes black on the drivers side. So it must be a bad o2 Sensor.
  5. #15
    Make sure your ETC wire didn't come apart..... I'm just saying........
    1989 Chevy V1500 Suburban 4X4, long tube headers & xover pipe. w/1985 350 4bbl.
    2002 Silverado 1500 5.3L Ext. Cab
    2005 Wrangler Rubicon 4.0L
    1990 Miata
  6. #16
    That would effect both driver side and passenger side, my problem is mainly on the drivers side. I will check that though, thank you.
  7. #17
    if nothing else changed except exhaust, then deduction leads me to believe it's something O2 sensor related. Remember too that positioning of O2 sensors effects how they read; the further back in the exhaust stream the sensors are, the more delay in the reading, and the longer it takes for them to heat up. It usually doesn't cause a MAJOR issue though; I'd expect it to be something in the wiring, etc. If it uses a 3 wire O2 sensor, you may have a grounding issue as well.
    1986 Chevy G20 Tow Rig - 5.7 TBI conversion
    1978 Mustang II King Cobra Road Racer - Holley 650, MSD 6AL, 5 speed, 10 point Roll Cage, 9" posi, fuel cell, custom interior.
  8. #18
    They are 4 wire o2 sensors, one o2 sensor on the passenger side is around 6" further down the pipe, because the bung on the header was put in an area where there is not enough clearance to put the 02 sensor back in it. Should i get the drivers side front o2 sensor moved back the same distance?
  9. #19
    nah, you really want them as close to the collector as you can get them. And that much difference really shouldn't matter side to side. 4 wires have ground included in the harness, so shouldn't be a grounding issue. I'd say next step try swapping O2 sensors between sides and see if the problem follows. If prob moves to passenger bank, you've got a bad O2. If not it may be something in the harness on the driver's side.
  10. #20
    I am picking up my new o2 sensors in a couple hours, the one o2 sensor is on the collector, the other is around 3 inches down the pipe, from the weld on the collector, but 6" from the bung on the collector. So i would say its only around 2" from the end of the collector. I hope it is just my o2 sensors, the symptoms my truck is showing is that it is either the o2 sensors, or fuel delivery problems. I will try my new o2 sensors and i will see if that fixes the problem. $110 a piece, what a joy. Also got new front wheel bearings and new ball joints, $200 a piece for wheel bearings, $89 a piece for ball joints. Best ball joints i could find.
Similar Threads
  1. Header help
    By mitchlbuck in forum GM Powertrain
    Last Post: 05-28-2010, 11:42 AM
  2. Header Mod
    By lifted98chevysilverado in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 05-03-2010, 08:09 PM
  3. Header question!?!
    By BLKDOUTZ in forum General Chevy & GM Tech Questions
    Last Post: 04-27-2010, 02:32 PM
  4. Replies: 1
    Last Post: 04-19-2009, 09:29 PM
  5. HEADER
    By doug in forum Chevy Colorado Forum (GMC Canyon)
    Last Post: 07-23-2006, 05:40 PM
