Results 1 to 10 of 12
Thread: blue bird bus
    Sr. Mechanic poncho08's Avatar
    Dec 2008
    where ever the pipeline takes me in canada
    Default blue bird bus
    this is so cool! i was over at my buddies parents place over the weekend halping them clean there yard and they had an old 1969 chevy blue bird school bus in there back forty. i asked them what thay where going to do with it and thay said that they were going to crush it. so i said ill take it if thay didint want it. so now i got a 69 school bus that im going to make into a RV. its got a 350 4 bolt main with a 5 speed stick so sweet hahaha
    08 LTZ 5.3L
    ext cab reg box
    ranch hand bumper
    74 gal slip tank in box
    magnaflow off the side in front of pass tire
    green preformance cold air intake
    airrade spacer
    bully dog tuner
    alpine nav deck JL10inch stealth sub and 350watt amp
    murdog94's Avatar
    Does she run???
    Mike
    Currently
    2011 F-150 Crew 4X4
    Dec 2008
    when thay parked it in 91 it did lol hope so
    murdog94's Avatar
    Sounds like a project... a fun one though...
    Are you going to try and fire the engine?
    Dec 2008
    going to try this comeing long weekend and see whats going to go wrong lol
    There are a couple things you can do to improve your success. Pull the plugs, give each cylinder a healthy dose of Deep Creep. It really needs to sit for several hours to work, give em a squirt every couple hours. You can change the oil while you're waiting. And make sure there is lube in the transmission. With the plugs out, try to turn the engine over with a socket on the front pulley. You want to turn it over at least two full turns to give the camshaft and valve train a full cycle. If it turns over OK by hand, a little more DC, then turn it over with the starter, plugs still out. If it sounds OK, and you are building a little oil pressure, put new plugs in and give it a try.
    You probably want to pull the dist cap and clean up or replace the points, make sure the cap and rotor are clean and look decent. And to make things easier, get a bucket rigged up with a fitting so you can gravity feed fuel to the carb. That way you're not dealing with pulling crap from the tank.
    Should be a fun project! Good luck!
    2010 Z/71 Colorado C/C
    Black 4X4 w/5.3L V8
    2007 Winnebago Adventurer
    w/8.1L Chevy & Allison 6spd.
    Canyon Lake, Texas
    Dec 2008
    Quote Originally Posted by 2COR517 View Post
    thax will do
    Sr. Mechanic SmokeU's Avatar
    Aug 2009
    Fitchburg, WI
    Have any friends with a nice video camera? I would love to see this project in a documentary format
    2004 Chevy Silverado w/ 5.3L V8 / Z71 / Shorty
    Would rather be going too fast then too slow:out:
  1. Blue HIDs
    By Prophet1990 in forum Lighting Discussion
    Last: 03-01-2010, 10:29 PM
  2. Blue Granite
    By flip66 in forum Chevy Silverado Forum (GMC Sierra)
    Last: 12-06-2009, 10:33 PM
    Last: 11-04-2009, 09:10 PM
  4. Blue LED Gauges
    By Z71_usmc_rebel in forum Chevy Truck Accessories
    Last: 12-29-2008, 10:04 AM
  5. FOUND MY BIG BLUE OX [Expired Topic]
    By gmcjohnny in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 09-07-2006, 06:45 PM
