    Default off topic airplane
    just for a diversion......
    what is the small vent like box in the bottom right of this pic of the Boeing 787. Its where the wing meets the fuselage on the bottom right....
    http://farm5.static.flickr.com/4029/...d2506536_m.jpg
    Good question. Is there an APU in there somewhere?
    murdog94's Avatar
    I am thinking that is the APU.. Or something along those lines..
    Mike
    Currently
    2011 F-150 Crew 4X4
    I looked up cabin pressurization on Wiki after reading this post. Bleed air off the engine compressors has been used to pressurize planes for years. But Boeing went back to electric compressors on the 787.
    o were too large and heavy, Sinnett says. "Now we have the weight, cost, power and reliability that works on an aircraft."
    There are four cabin compressors, two on each of the two air-conditioning packs in the wing-to-body fairing. They compress outside air to roughly 15 psia. and an outlet temperature around 200F. The 6,000-ft. cabin is at 11.8 psia. The compressor wheel is about one ft. in diameter and turns 42,000 rpm. on oilless foil air bearings, though the speed of the permanent magnet motor varies in practice. Each one can produce 90-100 hp. The ozone-removing catalyst normally operates around 350F entry temperature and engineers had to make sure it works at 200F.
    The low compressor pressure biases the heat rejection task away from the turbine-compressor air cycle machine, because it uses pressure drop for cooling. Instead, the new pack requires a larger radiator to dump the heat to outside air, and that increases cooling drag compared to current practice.
    hi,folks,
    the pic is good,it looks so heavy and its capacity also high i think so......
  1. Off topic sorry ATV'S
    By Mattdtrue in forum Photo & Video Gallery
    Last: 03-09-2010, 12:05 AM
  2. off topic
    By zackyv55146 in forum Photo & Video Gallery
    Last: 11-19-2009, 09:07 AM
  3. Way off topic..........
    By Grynder in forum The Coffee Shop ~ Chit Chat
    Last: 08-26-2007, 07:03 AM
  4. Off Topic
    By TrailLeadr in forum Photo & Video Gallery
    Last: 03-04-2007, 10:03 PM
