GM Truck Club
Page 4 of 9 FirstFirst ... 23456 ... Last Post byLast Post by
Results 31 to 40 of 90
  1. #31
    I Use Sea foam IN MY GMC My Mack & my lawn garden equipment. I Swear by it.
    later
    Mack
    94 GMC 2500 LWB : 350 4L60E Tranny 3:42 ratio rear end Homemade Headache Rack with rails,soon to have A/C WORKING & Windows tinted & soon to have Flowmaster w/ Echo tips.
  2. #32
    Jr. Engineer
    Aug 2010
    eas' bum fuk, maine
    doesnt the tahoe have hydraboost? if it does then boost is multiplied by the use of the power steering pump not vacuum and the master cylinder should sit on this fixture that has i think two steel lines running out of it and into yoru p.s system
    "i dont think you got the picture. i got a beautiful picture. this baby happens to have an extra turn of speed, which is the only thing i care about. you dont understnad what happens do you? they make cars. they make 'em exactly the same way. one or two of 'em turn out to be something special. nobody knows why. i know why. i may be kiddin' myself, but i think i can make somethin' out of that sad little bucket of bolts." ~ Tennessee Steinmetz
  3. #33
    when adding the seafoam to the fuel, does it matter on what level the tank is at? should i run it empty then put the seafoam in a the gas station and and fill 'er back up? or is there no preference?
  4. #34
    Master Mechanic clgoch187's Avatar
    Aug 2010
    Gettysburg, Pennsylvania, United States
    the more fuel in the tank the longer you'll be running it thru, so in my opinion 1/2 -2/2 is better than emptier cus it will be cleaning more and longer and if you put it in at a lower level you might get a rough idle for a while cus it doesnt burn off as good as gas
    03 Silverado 1500
    285/75/16 BFG's
    2 Blaupunkt 10" vW1000 subs in Subthump box
    ProComp Level Lift & 3" rear blocks
  5. #35
    ok sounds good, if I do it on about 3/4 tank, still recommend about 1/3rd of the can put in? or more?
  6. #36
    Quote Originally Posted by egreg View Post
    From what I've heard, there are three ways to use Seafoam - In the fuel tank, in the intake manifold (i.e. vacuum lines), or in the oil. I've put it in my brake booster line and in my gas tank before, but I'm skeptical about putting it in my oil. Thoughts on this?
    Been using SF in oil (along with the top end of the engine and intake) with great results...
    BUT!!!
    Add a can to the crankcase and a can to the gas tank at the same time, planning for an oil change. I say this since I would change the engine oil after about 200-300 miles (i.e. about a tank of gas). Don't run SF in the crankcase any longer since it will cause the oil to start to deteriorate as it works over the sludge and gunk in the engine. I will plan in an oil change and SF the top end (thru the vacuum line) and the TB in the same service. One tip that's worked well for me is to SF the top end and TB, drive it after letting it sit to clear out the crap and then do the oil change. That way everything is all cleaned up and then you change out the oil- good as new!
    Change out the oil and filter and drive the hell out of it!
    /r
    Allen
  7. #37
    Sr. Apprentice
    Oct 2010
    Panama City Beach, FL.
    Default Sea Foam in newer vehicles...
    So what about newer vehicles? Is this a good thing to run about every 2-3 oil changes? Maybe just for preventive maintenance...? Perhaps not the oil until about 35-40k but as far as fuel goes.. I would feel maybe a can in the fuel tank every 2-3 oil changes wouldnt hurt anybody... Ideas? Opinions?
    GO GATORS!!!
    2010 Chevy Silverado LT 4x4 Z71 Crew Cab
    5.3 L Vortec V-8
    Skid Plates
    Bluetooth, Steering Wheel Controls, Adjustable Pedals, all the goodies...:happy:
    Everything stock...
  8. #38
    Actually, I have been using SF in newer vehicles specifically in the gas tank. Since newer vehicles tend to have the filter in the tank (not owner replaceable) I have been using it to keep the tank and fuel system cleaned out. I'll add a can about once every 6 months and have never had a fuel related problem in the cars or bikes.
    As for the crankcase, I will use it about once a year just for good measure generally in the fall.
    /r
    Allen
    2010 Silverado Extended Cab 4X4 LTZ w/Z71
    2008 Tahoe 4X4 LT w/Z71
    1987 R10 Silverado 2wd short-bed (Wonder-Truck!)
    The only mustang in our house.... A NAVY MUSTANG!
  9. #39
    Murdog94 - When you say pour SF in the brake booster line at 1200 to 1500 rpm and then let sit, do you mean let it sit for an hour to 2 hours whiles its running or shut off?
    Thanks!
  10. #40
    Jr. Engineer
    Mar 2010
    Cochrane, AB
    Quote Originally Posted by Sportmod5 View Post
    Thanks!
    Let it sit with engine OFF. When you start up two hours later, go for a ride and enjoy the smoke show!
    SEAFOAM, I PUT THAT @#!$ IN EVERYTHING!
    2004 Silverado LS 5.3L Z71 Crew Cab
    260,000+ km
Similar Threads
  1. Sea foam
    By 98-chevy in forum General Chevy & GM Tech Questions
    Last: 09-27-2010, 08:45 AM
  2. Correct way to use Sea Foam through vacuum lines??
    By FergusonT in forum Maintenance & Upkeep
    Last: 09-11-2010, 11:14 PM
  3. 77 chevy 400 small block vaccuum diagram?
    By socal77k5 in forum GM Powertrain
    Last: 06-08-2010, 03:10 PM
  4. Sea Foam use
    By dsquared in forum GM Powertrain
    Last: 05-26-2010, 07:59 AM
  5. Sea Foam
    By Chad01 in forum Performance & Fuel
    Last: 02-17-2010, 12:09 PM
