Page 1 of 9 123 ... LastLast
Results 1 to 10 of 90
    Ortonville MI
    Default Sea Foam in Vaccuum Lines
    Did this to my truck and the wife's Ford Fusion last weekend what a difference. I put some in the Vacuum lines and in the tanks on both cars and it has made a significant difference. Her car was starting to start hard and it has completely cleared up. I also noticed today at O'riely's auto parts today that they had buy 2 get one free. Not a bad deal.
    07 NBS Crew cab SLT 4x4
    Seafoam rules.
    Master Mechanic Silverado Junkie's Avatar
    Feb 2010
    Lead Hill, Arkansas
    Seafoam is the only way to go.
    1995 Silverado,Z71, 3-inch lift,2-inch leveling kit, SkyJacker Suspension, short ram-air intake, throttle body spacer, MSD ignition coil, straight pipes
    Aug 2009
    Fort Washington, MD
    I have an 04 Tahoe with the 5.3 Vortec engine. How do you Seafoam this? I use the brake booster hose on my other vehicles but cannot find it on this vehicle.
    I pull the air snorkel off and dump it right down the throttle body.
    Ortonville MI
    Quote Originally Posted by Thunderchild View Post
    Ya I couldnt tell you without seeing a picture of your engine bay or looking at it!
    What's the purpose of this Seafoam stuff? What does it do?
    The Cheap-*ss Modder & Thread Killer
    The Realist says, "The glass is too big".
    2013 GMC Sierra 1500 SLT Z60 4WD Crew Cab
    Mineral Green Metallic w/ Tan Leather Interior
    5.3 L FLEX w/AFM, 6A, Cheap-*ss Mods
    32 Dump Club Member
    Range V8 AFM Eliminator
    Quote Originally Posted by BigBlueLB756 View Post
    it's suppose to clean up your fuel system & any carbon build. here's a link to the actual site: http://www.seafoamsales.com/gasoline-engine-faqs.html
    after hearing peoples testimonies about seafoam on youtube and on forums that i'm on, i figured i'd give it a try. i was very much impressed with the results. my cherokee idle smoother and runs like a champ even more.
    2K Bowtie Silverado xCab 5.3L
    7" Fabtech Suspension Lift + 3" Perf Acc. Body Lift
    K&N Air Intake + Edelbrock Shorty Ceramic Headers + Flowmaster Super 10 Series dumped after muffler!
    Bridgestone Dueler 285/75/16 on stock rims
    SSBC Slotted Rotors & Pads
    HID Driving & Fog Lights
    (AR Bajas + ProComp 305/70/16) <-- seasonal set
    Thanks! I'll check it out. Sounds like something the Tahoe would like.
    For the tahoe, there is a big black container that has your brake fluid in it with the tubing going down, there will be ONE rubber hose going to the back of your intake manifold, disconnect it and put a funnel on the end, start the engine, and slowly pour the seafoam in. It may stall, but thats fine start it back up and keep pouring slowly.
    www.youtube.com/ippielb
  1. Sea foam
    By 98-chevy in forum General Chevy & GM Tech Questions
    Last Post: 09-27-2010, 08:45 AM
  2. Correct way to use Sea Foam through vacuum lines??
    By FergusonT in forum Maintenance & Upkeep
    Last Post: 09-11-2010, 11:14 PM
  3. 77 chevy 400 small block vaccuum diagram?
    By socal77k5 in forum GM Powertrain
    Last Post: 06-08-2010, 03:10 PM
  4. Sea Foam use
    By dsquared in forum GM Powertrain
    Last Post: 05-26-2010, 07:59 AM
  5. Sea Foam
    By Chad01 in forum Performance & Fuel
    Last Post: 02-17-2010, 12:09 PM
