    Default 1996 Silverado Z71 problem
    1996 chevy 4x4, the truck cranks and runs fine until i reach 50 mph, then it spits and sputters and wont go any faster, i shut the truck off and wait a few seconds and crank it back up and it runs fine until i get to 50 mph. the truck also takes a long time to shift between gears, to my knowledge there is not a shift kit installed in the truck. Any ideas?
    Sr. Engineer
    Aug 2009
    Virginia Beach, VA.
    Transmission fluid change maybe?
    may be for the shifting problem, but what about the rough running at 50 mph
    When was the time you changed the fuel filter?
    Master Mechanic Silverado Junkie's Avatar
    Feb 2010
    Lead Hill, Arkansas
    Yep, I agree, a clogged fuel filter will make your truck fall flat on top end and spitter and sputter.
    1995 Silverado,Z71, 3-inch lift,2-inch leveling kit, SkyJacker Suspension, short ram-air intake, throttle body spacer, MSD ignition coil, straight pipes
    fuel filter is good, im getting 60 psi on the fuel rail, giving me a code of T0122
  1. 1996 Silverado
    By GatorLM13 in forum General Chevy & GM Tech Questions
    Last: 05-29-2010, 11:26 PM
  2. 1996 Yukon Vibration Problem
    By YukonJake in forum GM Powertrain
    Last: 02-01-2010, 11:56 PM
  3. 1996 silverado 4x4
    By davidb in forum Member Introductions
    Last: 02-24-2009, 05:04 PM
  4. 1996 Surb alternator problem?
    By raueda1 in forum Audio, Video & Gadget Tech
    Last: 12-26-2008, 08:51 PM
  5. My 1996 Silverado.
    By tillyb1989 in forum Chevy C/K Truck Forum
    Last: 05-19-2008, 02:13 PM
