Results 1 to 2 of 2
    Default blower motor problems
    Last Winter while I was in Mexico My blower motor quit working. Yesterday when I replaced the resister it started working and I thought everything was fine. As i was putting the cover back on I started smelling an electrical smoke. The blower seemed to freeze and I shut it off.
    Has anyone had a similar experience? It seems to me that it is probably the motor, but I'm not sure,any ideas?
    I just had the same problem on my 06 2500HD. No speeds worked at all. While the key was on, and the blower turned on, I tested the red wire to my blower, it was hot, so I thought the motor was toast. I decided to test the continuity of the circuit by unplugging the red/black lead to the blower. With it unplugged, i placed my test light accross the black and red connections of the blower wires... I was not getting a connection to ground on the black wire. I disconnected the other end going to the resistor pack. I looked at the ground wire connection pin and it was pretty black and dirty, looks like a little arcing was going on maybe. I cleaned up the connection with a file and small pin, connected everything together and it works fine now. I suspect someone's foot may have kicked the connecter and got it a bit loose. It's ok for now, but I may have to either replace the connector or jumper the ground wire around the connector. Good Luck
  1. Blower Motor
    By TheShamrock7 in forum Chevy Trailblazer Forum (GMC Envoy)
    Last Post: 05-12-2010, 11:15 AM
  2. Rear Blower Motor Problems.
    By Murfdogg's95 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 12-21-2009, 08:14 PM
  3. Chevy Silverado Heater problems blower problems
    By bidutch in forum GM Powertrain
    Last Post: 12-13-2007, 05:59 PM
  4. Blower motor problems chevy colorado
    By markeus in forum GM Electrical Tech
    Last Post: 11-28-2007, 06:52 PM
  5. Blower Motor Resistor Problems
    By TheShamrock7 in forum GM Powertrain
    Last Post: 10-21-2007, 02:48 PM
