    Default am i wasting my money with this
    im thinking about putting new torsion keys in on my 97 gmc k1500 4x4 i already have the 3 in body lift, i need just about 2 in or so to clear my thirty three s on 15x10 rims, but i ive heard alot bad things about new keys and cranking up the bars, what would be the best way to go, also how do the keys actually work do you leave the adjusting bolts in the same location once the new keys are installed or do you have to crank them up more, and info would be nice and if anyone has pictures of this setup on my year of truck would be great.
    Master Mechanic Silverado Junkie's Avatar
    Feb 2010
    Lead Hill, Arkansas
    No your not wasting your money. New torsion keys are great.Cranking your stock torsion bars or installing new keys dont have any negative affects on the truck besides putting a little bit more stress on your front end components. You can only get a certain amount of height out of your stock torsion keys, so thats where aftermarket keys come into play. Aftermarket keys are shaped at a different angle than the stock keys allowing you to turn the adjuster bolts more and get more heigth. I would get them if I were you.
    1995 Silverado,Z71, 3-inch lift,2-inch leveling kit, SkyJacker Suspension, short ram-air intake, throttle body spacer, MSD ignition coil, straight pipes
    Quote Originally Posted by Silverado Junkie View Post
    once you put the new keys in how do you know how much to turn the adjuster bolt to get the correct amount of height
    Feb 2010
    Lead Hill, Arkansas
    Take a measurement of distance between your tire and fender well or from your front bumper to the ground, whatever would work for you. Then install your keys and start turning your bolts untill you get to your desired height. So if you buy 2 inch keys, then crank your adjuster bolts untill your front end is 2 inches higher than stock. Thats why you take a measurement of height in the front before you instal new keys.
  1. yes savin money
    By 00loudchevy in forum The Coffee Shop ~ Chit Chat
    Last Post: 11-03-2009, 05:07 PM
  2. BDS Worth the money?
    By ippielb in forum Lifted & Offroad Suspension
    Last Post: 08-14-2009, 05:10 AM
  3. The Big Money: Could GM be cool again?
    Last Post: 06-04-2009, 01:16 AM
  4. GM may need more money, COO says
    Last Post: 01-12-2009, 08:40 AM
  5. tax money????
    By vncj96 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 11-30-2008, 09:29 AM
