    Default ABS warning light/ speedometer/ transmission Issue?
    I have a 97 Tahoe 4wd W/automatic transmission. I have just had a problem I hope someone can help me out with. After driving at highway speeds 65-70 for about 25 miles as I slowed then stopped the ABS warning light came on the speedometer went to 0 and it seemed like the transmission was disengaged or slipping. I put in neutral then back into drive, nothing. I slipped it down into 3rd, nothing. When I put into 2nd it ran and I was able to go the mile home with the speedometer staying at 0. After sitting awhile it seems ok and moves in reverse and in drive, and the ABS warning light is gone. What gives? Is this a break issue causing the computer to disengage the transmission to or is it a transmission problem giving an ABS warning light? Where do I start?
    Thanks for any help you may offer.
    Doug
    PM sent
    Hoping someone can chime in here i have a 2002 Z71 with the exact same issue and i have replaced both wheel bearing(front)with wheel speed sensors and a vehicle speed sensors.Checked all the grounds and connections.Hoping someone has had a similiar scenario here.
    Thanks in advance,
    Mike
    murdog94's Avatar
    For you it sounds like a PCM issue to be honest since the PCM gets its signal from the VSP, and sends it to the speedo.
    As to the problem above i would start with a Vehicle speed sensor.
    Mike
    Currently
    2011 F-150 Crew 4X4
  1. Speedometer Issue
    By Waco in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 01-15-2010, 05:13 PM
  2. Batery warning light and odometer light on - help
    By filmir in forum General Chevy & GM Tech Questions
    Last Post: 09-29-2009, 11:54 AM
  3. warning light?
    By capt sensible in forum Audio, Video & Gadget Tech
    Last Post: 07-12-2009, 09:47 PM
  4. Abs Warning Light
    By ejamin73 in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last Post: 08-21-2007, 08:06 AM
  5. gas guage warning light
    By matt in forum Chevy Trailblazer Forum (GMC Envoy)
    Last Post: 01-30-2006, 12:24 PM
