Results 1 to 10 of 11
Thread: Bad Valve?
    Default Bad Valve?
    Ok, I've got a 1999 Suburban with 181,000 miles on it. 350 Vortec. On Mon. it started pinging badly. I pulled a code that was #6 cylinder misfire. Replaced the cap, rotor and wires as they were all looking a little beat up. #6 spark plug was wet. I did a compression test on all cylinders. Got about 150 psi across the board, except for #6 and #4. They were both around 30-40 psi. I put a few squirts of oil in the cylinder and the compression stayed the same. So, I'm assuming the rings are fine(no blue smoke out of the exhaust), all I can think is that it's a carboned up valve or valves. I ran some Seafoam through it. Made lots of smoke but still had the rough idle, detonation and the same code. I may run a little more Seafoam through, but, looks like I'll be pulling the heads this weekend. What I'm thinking of doing is getting some new or rebuilt heads, an aluminum intake manifold, water pump and all the little things I come across. Am I barking up the right tree? Looking for some advice on where to go from here. Thanks
    murdog94's Avatar
    What are you looking to do? Are you looking for more power? and if you are looking for ease of use and design keeping the factory intake is just fine as well.. A little port matching etc might help some.. But if you arent going for a built motor I would just rebuild it fairly stock, and if you want more power i would build a new motor for it since the bottom end has so many miles on it. If you remain fairly stock 300K miles isnt uncommon for these motors.
    I guess the aluminum parts that you are looking to use really arent needed since the stock components are pretty good.
    I would go with a programmer a set of headers, and a cold air intake. and just clean everything and a good port matching otherwise id keep this motor stock..
    Mike
    Currently
    2011 F-150 Crew 4X4
    Identicle to what happened to my 99 it was a bad valve. for me they rebuild both heads but had I known what it was gonna really cost me to try and figure out the damn valves I would have just got a new motor and transferred the asseccories to the new motor
    Hypertech III, K&N, true dual
    285/75/16
    ___________________________
    Jason
    murdog94's Avatar
    Good Point on that.. And then you have a new motor good for another 200K miles...
    Jun 2006
    Good point.
    You can get a NEW GOODWRENCH from Pace Performance for $2250 delivered to your curbside.
    This is a new genuine GM motor not some BS aftermarket cheapo rebuild.
    One of the huge advantages GM trucks have is cheap ,readily available parts. It actually makes sense to keep them running for 20 years.
    It would cost 5X as much to by a Toyota or Nissan V-8 and 2x as much to get a Ford or Dodge V-8.
    1998 suburban-
    1/2 ton
    199500 miles
    River
    Ridge,LA
    X2 on the Goodwrench crate motor.
  1. '93 with a 4L60E? no TV valve,
    By strantor in forum GM Powertrain
    Last: 08-27-2010, 03:19 AM
  2. EGR valve boogers
    By andrewh in forum Chevy Blazer Forum (GMC Jimmy)
    Last: 02-08-2010, 08:04 PM
  3. valve adjustment?
    By sparky09 in forum GM Powertrain
    Last: 02-18-2009, 09:05 AM
  4. Valve Problems?
    By mattyV in forum General Chevy & GM Tech Questions
    Last: 02-17-2009, 08:19 PM
  5. pcv valve?
    By chazawazzle in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 01-13-2009, 08:20 PM
