Thread: blew the rear
    Default blew the rear
    hi all. im in a little bit of trouble. i blew my rear to pieces. im in a bit of a bind as far as time so i wanted to get a junkyard rear. i have a 1990 suburban 1500 4wd with a tbi 350. now i know there are many axles that will fit. but im just trying to see which models i can yank the whole rear from and go. i have 3.42 gears in mine but im not terribly concerned with the ratio i end up with now. can any one give me a few other trucks that i can plug and play with the rear? thanks so much for any insight that can be contributed.
    murdog94's Avatar
    Just about anything with that body style. (mid 70s Chevy/GMC fullsize 1/2 ton with a 6 bolt axle) will fit.
    Mike
    Currently
    2011 F-150 Crew 4X4
    Quote Originally Posted by shagginwagon View Post
    You can't use your 4X4 unless you match the gear ratios...Do you have a shop nearby that does rears? Sometimes they have rebuilt guts available that could be stuffed into your rear...might not bee that much; shop around some...for that era 3:42 was pretty common so someone should have the stuff you need.
    2006 Impala LT 3.5L
    I wasn't concerned as much with 4wd usage as much as gettin the truck Rollin for pop again. I lucked out and found 1990 k5 axles 3.73 front and rear for 300 beans. Even better yet there's some kind of locker in it. Definetly not a limited slip. Has centrifugal weights on it. Thanks for the help. I anticipated a disaster and managed to upgrade while repairing. Couldn't be happier.
    murdog94's Avatar
    300 is a good deal.. glad youve got it going again.
  1. i think my motor just blew:s
    By kawasaki_kid in forum General Chevy & GM Tech Questions
    Last Post: 12-30-2013, 06:44 AM
  2. blew my 4X10.... in my 92 sonoma.. where can I get something?
    By Falcone in forum Audio, Video & Gadget Tech
    Last Post: 08-06-2009, 07:24 PM
  3. My trans blew up!!!
    By lube70 in forum GM Powertrain
    Last Post: 04-19-2009, 09:28 AM
  4. my engine blew (sigh)
    By scgamer_99 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 03-23-2009, 10:44 AM
  5. I blew my transmission to hell and back again
    By Crawdaddy in forum GM Powertrain
    Last Post: 03-02-2008, 08:48 AM
