    Legend unplugged's Avatar
    Sep 2006
    High Deserts of SoCal
    Exclamation Help with differential cover
    Well, I'm ready to upgrade the rear differential cover. I'd like to get one that has a drain plug to make gear oil changes easier. I'm leaning towards steel instead of aluminum, since I do get off road. I checked out the JC Whitney site and all they show is the basic chrome. Anybody use anything different?
    High Desert SoCal
    02 Honda Civic LX
    Quote Originally Posted by unplugged View Post
    I'm not a huge chrome fan but look up this little number seems to be interesting and tougher for what you need. Pretty is not always better...
    TA Performance rear end girdle. It's stronger than the AAM cover that was part of my SLP Auburn upfit option and also provides supports for the main caps. It comes with allen head bolts, washers and a nice gasket that looks the same as the Chevy parts (GM 26016661). The one advantage the AMM cover had is that it has a cooling channel built in; oil flung from the ring gear enters it and exits on the carrier bearings.
    Jamie
    that's one bad-ass diff cover Cableguy! I'm just not sure that I want to spend $160US to buy the blasted thing. I guess that'll be at the bottom of my list of stuff to get
    Christopher
    Ya it is kinda expensive isn't it. Didn't look to big to me (Although I can't see it from side profile). I was looking for something more indestructable for unplugged. In case he got hung up in rocks. It looks cool too
    BTW I've had the chrome ones and there junk for off-roading.
    Chevy Truck Parts
    Chrome looks nice, but it doesn't seal well. If you go with the chrome, see if you can remove the chrome from the mating surface.
    Gary
    99 K 1500 Suburban
    00 S-10 Blazer
    1976 Trans Am
    1980 Honda CB900 Custom
    Sep 2006
    Wow, those are very cool covers. But there is no way I can justify dropping $150 on a new cover. If I ever get around to building a high horsepower rig, these would be an option, but I guess I'll poke around for a deal on a steel cover with a drain plug and maybe a temp sender port.
    The Mag-Hytec worked well for me. O-ring seal has no leaks, extra capacity for more Mobil 1, dipstick to check fluid level, temp. sending port, and drain plug. I use one on the transmission also.
    Looks great and keeps things cool, unlike chrome which retains heat.
    1998 K-2500 Suburban
    454 w/ 4L80E
    Suspension Maxx T-Bar Keys Gibson Cat Back K&N Intake
    Mag-Hytec trans pan and diff cover Hypertech Programmer
    MSD 6A, Blaster Coil & Wires Roadmaster Active Suspension
    Hummer H2 wheels w/ BFG All Terrrain T/A KO
  1. Help with a differential question
    By dranderia in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 01-02-2010, 09:00 PM
  2. Differential
    By Williys in forum Chevy Uplander & GM Minivan Forum
    Last: 08-08-2009, 09:31 PM
  3. What front differential in 06' 1/2 ton?
    By gocubs68 in forum GM Powertrain
    Last: 05-30-2009, 09:06 AM
  4. I want a new differential
    By CarpenterGuy in forum GM Powertrain
    Last: 08-24-2008, 07:15 PM
  5. rear differential
    By brooklyn718 in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last: 05-19-2008, 11:55 AM
