    Default coolant temp sensor
    So i was changing out my negative battery cable today and bumped my hand on the coolant sensor that threads into the intake manifold, and i guess after 15 years the plastic became brittle so it snapped right off. from what i can tell this just sends a signal to my dashboard for my temp reading.
    Does anyone know if i can leave it unhooked and still drive the truck until i get a new sensor this weekend? Also, what are my chances of actually being able to unthread the sensor after 15 years?
    Thanks
    Brian
    Brian
    Frederick, MD
    1995 Chevy truck
    223,000 miles and counting
    :fighting0098: chaos, panic and destruction...my work here is done
    GM ALL THE WAY BACK
    2007 Chevy Imp
    2006 Chevy Colbolt
    2007 Suburban
    1986 Camaro
    1996 Saturn
    1999 Saturn
    1996 Oldsmobile
    1995 K1500
    Jr. Engineer hundojoe's Avatar
    Feb 2010
    Elk River, Minnesota
    Its prolly not going to run very well, im sure it will throw a check engine light and run in limp mode. the coolant sensor dosent just run the gauge it also tells the computer how hot the motor is obviously, but it also has to do with timing and fuel trim.
    murdog94's Avatar
    You broke the Sensor and not the switch right?? the sensor will make your truck run rough since it sends the temp to the computer to determin your fuel trims, and the switch mounted in between the #1 and #3 cylinders on the head. The Switch is what sends the signal to the guage on your dash.. It wont even really go into limp mode it wil just run really really rough.. So id advise that you dont drive it.. The switch should be about $15 mabey less.. I just had to replace mine on my old truck.. And it is a brass fitting it will actually come out quite easly.
    Mike
    Currently
    2011 F-150 Crew 4X4
    Thanks for the info guys. I changed it out tonight with no issues.
  1. Coolant Temp Sensor vs. Temperature Switch
    By Googenheimer in forum General Chevy & GM Tech Questions
    Last: 02-23-2010, 02:43 PM
  2. Coolant Temp Sensor
    Last: 02-22-2010, 11:50 AM
  3. engine coolant temp warning
    By thekingsphance in forum GM Powertrain
    Last: 08-12-2009, 10:20 PM
  4. Changing the Coolant Temp Sensor
    By Crawdaddy in forum GM Powertrain
    Last: 11-08-2008, 06:32 PM
  5. '82 diesel, coolant temp sensor, Where?
    By kbarrett in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 07-16-2007, 09:10 PM
