    Default Check engine light on.
    Last night my check engine light came on after i had gone through some deep water from a flood, and i hooked up my tuner and the diagnostics said this "mass or volume airflow circuit low input." what exactly does this mean, and what should i do? thanks for all input!
    03' Silverado 1500 HD
    K&N CAI, Diablo Programmer
    probably means you got water into the intake and onto the Mass air flow sensor. get a can of mass airflow sensor cleaner and try that. If it doesnt fix it you probably messed up the sensor and will need a new one.
    David
    1960 Land Rover Series II 88
    2001 Pontiac Sunfire
    NRA Life Member
    X2 what dsfloyd said, but I would also spray the elec. plug to the MAF with electrical cleaner to clear any water that may have gotten into the plug.
    murdog94's Avatar
    Also take a look at your air filter etc to make sure there isnt any moisture that will cause a problem after you do get it repaired.
    Mike
    Currently
    2011 F-150 Crew 4X4
    I had cleaned it and the check engine light went off. thanks!
  1. Check engine light
    By old teacher in forum GM Powertrain
    Last Post: 05-17-2010, 08:03 AM
  2. check engine light
    By DTRJAG in forum GM Powertrain
    Last Post: 11-10-2009, 05:06 PM
  3. Check Engine Light
    By Nevada Born in forum Chevy Trailblazer Forum (GMC Envoy)
    Last Post: 12-27-2008, 01:18 AM
  4. check engine light
    By ss_silverado_phoneix99325 in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 10-04-2007, 08:57 PM
  5. 99 5.3L check engine light
    Last Post: 10-03-2007, 05:31 PM
