    Oct 2009
    Fairbanks, Alaska
    Default Belt Chirp Squeak Not Squeal
    Hi Everyone,
    I'm sorry ahead of time if I'm beating a dead horse to death but this issue of mine has been bothering me. So, basically I hear a subtle chirping noise (the type I cant hear with the radio loud and my girl next to me). At idle I can hear the chirps but it is most prevalent when the rpms are higher. It does this in neutral, reverse, drive and any other gears I can think of. So that narrows it down pretty much to the belt.
    Bottom line.
    The belt could be misaligned or something. The belt is new since May 2009. I put maybe 7k miles since. The truck has a total of 44k miles if that helps. Do the bearings wear?
    Please any help would be greatly appreciated,
    Alaskan
    2006 Chevy Silverado 5.3L Z71 Crew Cab
    Additions:
    Viper Auto Start / Security System
    PIAA 520ions ( Mounted in grill now )
    Magnaflow Cat-Back
    6000K HID Low Beams
    Homemade Projectors
    Definitely more to come
    murdog94's Avatar
    I would take a look at the idler puller, and the tensioner pully since these are the ones that the bearings ususally wear out on first.. Plus what type of belt did you put on the truck? Some of the cheaper brands will squeak a bit.
    Mike
    Currently
    2011 F-150 Crew 4X4
    Oct 2009
    Fairbanks, Alaska
    Thanks murdog94 and caddiac,
    I got some time today and had this idea. I was thinking that I could isolate the problem are by adding some pressure to each of the bearings. So I took the end of a wooden broom and actually got a result. The chirp only went away when I applied pressure to the end of the power steering pulley. So I immediately thought, "&*^%, I gotta replace the whole power steering pump." But I hope I'm exaggerating there. Have you guys ever heard of having to replace this item?
    Thanks Again
    Additions:
    Magnaflow Cat-Back
    6000K HID Low Beams
    Homemade Projectors
    murdog94's Avatar
    Yes i have heard of bad power sterring pumps in these trucks.. However i would remove the belt and see how much play is in the pulley. and the other pullies as well. That way you know for sure before you pay for a pump that you may not need.
    Mike
    Currently
    2011 F-150 Crew 4X4
    I had a chirping noise coming from under the hood near the serpentine belt, found out it was the alternator pulley. I took caddiac's advice and sprayed WD40 onto the pulley - noise went away. Thanks.
    So I ended up replacing the alternator. The WD40 worked temporarily then the chriping came back. I think the bearings were going bad near the pulley.
  1. Belt Squeal
    By szn9rg in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 01-23-2012, 01:25 AM
  2. belt squeal on 305 vortec because of alternator pulley?
    By treykelly84 in forum General Chevy & GM Tech Questions
    Last Post: 12-17-2011, 09:59 AM
  3. Alarm Chirp 2005 2500HD
    By jschoend in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 07-23-2010, 01:41 PM
  4. High Pitched chirp/squeek in 2000 Sierra
    By mledford0005 in forum General Chevy & GM Tech Questions
    Last Post: 05-05-2010, 04:47 PM
  5. Interior Squeak/Chirp vent related
    By Smoker_98 in forum General Chevy & GM Tech Questions
    Last Post: 07-07-2009, 01:05 PM
