Thread: lift the rear
    Jr. Mechanic drwdominance's Avatar
    Feb 2010
    Bowmanville Ontario
    Default lift the rear
    I have an 07 Sierra Classic with a leveling kit but when I tow I get the reverse rake look. What is the best way to lift the rear? A 2" block or an add a leaf?
    07 Sierra Classic, 5.3L, 4X4, Crew Cab
    Volant CAI
    Leveling Kit
    305/55/20 LTZ
    Flowmaster muffler
    Diablo Predator
    I have the same problem so I went with an all around 2in leveling and an add-a-leaf. It has a 2in spacer up front, 2in block and the add a leaf. Its raked like stock but lifted. I think under tow weight it will be level. Some people told me to go with overload springs or do the air bag helper thing. I like the add-a-leaf because its always there no need to add air.
    2009 Silverado ext cab long bed black- 2in lift front + rear, add-a-leaf, K&N filter
    2010 Ford Escape completly blacked out- K&N filter
    50cc pit bike- swing arm stretched 12"
    Go with the air bags for sure. They are reasonable and work great.. You can put any psi up to 100. They work slick you just add air into each valve an it's instantly level..
    1999 GMC Sierra 1500 5.3L 4x4 Long Box
    Feb 2010
    Bowmanville Ontario
    Quote Originally Posted by fxracerx View Post
    what kind of add a leaf is it? how many inches did it give you?
    I just sent a Ready Lift back for a refund after reading some threads. I figured I was not looking at the end result, I need spring strenth not lift. I haul alot of dirt and mulch. Better to benifit with the extra spring. After installing the front leveling kit the rear sags.
    Sr. Mechanic
    kburb's Avatar
    May 2010
    Blythewood SC
    A block will be the cheapest and will not alter your ride, a add-a-leaf will increase the arch in your spring and stiffen up the ride, but not much and depending on the wheel base you may never even fell a difference. Add-a-leafs are good for 1 1/2 to 2 inches of lft and will require you to unbolt the spring pack and insert the extra leaf. Still easy but the blocks are still the easiest thing to do.
    91 Suburban
    D44/14BFF w/Disc conv - Yukon 4:88's - Yukon Grizzly Lockers F/R -13" lift - DIY4x Shackle Flip - 37 ATZ on 18 MT Classics - Doug Thorley headers - Magnaflow - Holley Pro Jection Intake - Ultimate TBI mods - Hydroboost Brake Conversion - Hysteer-X Over Conversion.
    (Coming up - Fuel Injected 383 Stroker - Divorced NP205 - D60 - 40" tires)
    Just had a sping put in the rear today raised the back up from 39" to 41" front at 39".
    It put the rake back in and put some support back into the bed when I carry junk in the trunk.
    Couldn't be happier, no loss of ride comfort. Rides like a truck the way it should.
    here is the end result $318.00 better than blocks in my opinion. Good looks plus functional...
  1. rear end lift?
    By k/4x4/93 in forum Lifted & Offroad Suspension
    Last: 03-25-2010, 12:01 PM
  2. rear lift blocks....
    By DSpivey in forum Lifted & Offroad Suspension
    Last: 03-13-2010, 02:50 PM
  3. Rear Lift
    By canislupis69 in forum Lifted & Offroad Suspension
    Last: 03-02-2010, 06:29 PM
  4. Rear end lift
    By Jonesygmc in forum Member Introductions
    Last: 09-21-2009, 07:32 PM
  5. need help how to lift rear 2in
    By chevybulldog6 in forum Lifted & Offroad Suspension
    Last: 05-23-2009, 10:13 AM
