    Default Distributor help on a 7.4L Vortec
    Hello
    I just go a 96 3500 CC with a 7.4L vortec and was told that the distributor is at the rear of the engine. I have a maze of large hoses going across the rear and can only see the wire boots. How to I get the the cap and rotor on these engines?
    Thanks
    Joe
    99 Suburban 2500 4x4
    06 Explorer Ltd 4x4
    Not too hard to do.... Remove a couple of bolts to get the coil/map sensor bracket out of the way, a bungie cord to pull the AC line to the side. Then the cap is acessable, it helps if your "small"and can sit with your feet in the engine bay and just lean over top of the intake.
    Quote Originally Posted by rowekmr View Post
    Hello
    Thanks
    Joe
    I'm not an expert about doing this but i learned from this manual: Here's how to replace a distributor cap and rotor. http://www.mirage-performance.com/te...rcaprotor.html. Months ago, there has been a problem with my distributor. it's not functioning well so i pay for a mechanic service. When i got home, i seen this guide and realized i could done it on my own....tsk tsk...but now that i saw you in need of help, i'll share this guide....hope it helps.
    lucky to have the wealth and the pleasure....cheers:glasses:
    I've never understood why Chevy put the distributor at the back. Well, I know part of it is to do with the oil pump. And I suppose any camshaft/timing chain failure would immediately stop the spark. And there are probably dozens of other reasons.
    But another inch of clearance back there would be huge.
    As for accessing the distributor, start by removing the air cleaner snorkel. I open the snaps to the filter housing, disconnect the MAF & air temp connectors, unscrew the plastic "wing nut" at the throttle body, and lift the entire assembly out. Pretty easy to see the dist now.
  1. Vortec Distributor
    By rusty_buckets in forum General Chevy & GM Tech Questions
    Last: 02-08-2012, 02:39 AM
  2. Remove the Distributor?
    By vulcania in forum GM Powertrain
    Last: 05-29-2010, 09:04 AM
  3. Bad Distributor??
    Last: 02-11-2010, 03:22 PM
  4. 1997 Chevy Vortec Distributor - Broken Screw Flange
    By 4wd-burban in forum GM Powertrain
    Last: 10-16-2009, 08:47 AM
  5. Distributor issue?
    By artlock in forum General Chevy & GM Tech Questions
    Last: 08-17-2009, 07:51 AM
