Results 1 to 9 of 9
    Exclamation high temp on 95 suburban 454
    hey, my dad has a 95 suburban its a 2500 454, his temp gets up to 240-260f in a stand still, while moving its around 220-230f, we flushed the radiator, and it dropped the temp a little. is the temp supposed to be that hot? and if not what should we do?
    thanks for any help
    mike
    murdog94's Avatar
    Time for a T-stat... It should be no higher than 210 I would install a 185 T-stat... Also see if the clutch fan is engaging... Also Is it leaking/using coolant?
    Mike
    Currently
    2011 F-150 Crew 4X4
    im assuming the clutch fan is the fan right next to the radiator? if it is then yes it goes on. its not leaking, and i believe it uses it, we have open up the cap for the radiator to watch it move. thanks for the help.
    mike
    murdog94's Avatar
    What i meant by uses it is do you have to add any after it was filled? Because it is running nearly 30degrees hotter than it should.. Anything over 210degrees is damaging to the motor.
    Jr. Engineer hundojoe's Avatar
    Feb 2010
    Elk River, Minnesota
    Id put in a new water pump if your has a ton of miles on it, and like above thrown in a new thermostat, also see if the radiator hoses are collapsing pinching off coolant flow.
    1999 Silverado Regular Cab Short Box
    Black on Black, Line-X sprayed in bed liner
    5.3 with K&N CAI, Texas Speed 220/220 cam with 112 deg LSA
    Texas Speed computer Tune
    American Racing Headers with Cats
    4.11 gears front and back, with Eaton rear posi
    Flowmaster 40series true duals
    16X8 American Racing Nitros with 305/70/16 Goodyear MTR's
    285's in the pic
    If it ain't broke...........Give me a minute!
    Im not completely useless, I can be used as a bad example...
    Try "Water Wetter" too, the 7.4 engine doesnt take much to make it run on the hot side even when everythings working like it's supposed to.
    My 454 in my 90 had overheating issues, so I took it to a friend at the local repair shop and they used a "sniffer" to smell the rad coolant for hydrocarbons. It was alot higher then normal, indicating combustion gases were entering the coolant, the head gasket was leaking. There were no other indications of a head gasket issue, I even tried a t-stat and new waterpump beforehand. I replaced the head gaskets, surfaced the heads and the truck is perfect now!
    PS be careful when changing waterpumps because there is a reverse rotation for fuel injected engines and a forward rotation pump for carburated engine and they bolt up to either engine.
    we got a new t stat and the temp doesn't go past 210, so i am assuming that was the problem. we haven't had to add anymore coolant after the flush.
    thanks for the help murdog, and every one else.
    murdog94's Avatar
    Glad you got it fixed...
  1. 1989 suburban coolant temp fluctuation
    Last Post: 04-09-2010, 10:15 PM
  2. 2003 Z71 Suburban Temp Gauge
    By gaborn73 in forum GM Electrical Tech
    Last Post: 01-06-2010, 06:19 PM
  3. Looking at high mileage Suburban
    By drifteral in forum GM Powertrain
    Last Post: 01-03-2010, 01:21 PM
  4. Water temp cycling high and low
    Last Post: 07-26-2009, 09:50 AM
  5. High temp and oil pressure
    By i_build in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 06-28-2009, 07:51 AM
