    Default 05 Suburban mileage
    My 05 Suburban with a 5.3 motor that has 72000 miles on it, recently started getting 15 mpg instead of the 18 to 20 mpg that it normally gets around town and I noticed that the oil pressure guage is pegged at 80. The truck seems to be running fine just getting bad mileage and the oil pressure has me conserned. Thanks in advance.
    murdog94's Avatar
    Are you getting the 15mpg per the DIC or actually filling the tank and checking the miles?? Since it sounds like either lost the sending unit for the motor, However you do have the recall year truck.. If you search the forum there is info about the reacall information. since your have a grounding problem with the oil pressure guage.
    When was the last time you did a fuel filter? or an Air filter since those can cause problems with milage.. also you are getting up there in miles so it might be time for plugs.
    Mike
    Currently
    2011 F-150 Crew 4X4
    Thanks. Just changed the oil (full sythentic), fuel filter is due next change as well as the air filter. I check the mileage by the numbers, not trusting the computer. I will deffinately do some checking on the forum. Thanks again.
    murdog94's Avatar
    Yep i had the same computer in my Silverado and it was consistently 1-2mpg off either way. So i actaully never knew my actual milage.
    Mike
    Currently
    2011 F-150 Crew 4X4
  1. '95 Suburban with horrible gas mileage...
    By KirkW in forum GM Powertrain
    Last Post: 12-28-2010, 08:59 PM
  2. 2002 Suburban gas mileage dropping
    By jstiene in forum Performance & Fuel
    Last Post: 01-23-2010, 10:46 PM
  3. Looking at high mileage Suburban
    By drifteral in forum GM Powertrain
    Last Post: 01-03-2010, 01:21 PM
  4. Suburban Fuel Mileage
    By omnisi in forum Performance & Fuel
    Last Post: 03-23-2009, 08:34 AM
  5. Tracking my mileage- '99 Suburban w/454
    By Springthing in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 03-13-2009, 07:47 PM
