GM Truck Club
Page 2 of 4 FirstFirst 1234 Last Post byLast Post by
Results 11 to 20 of 39
  1. #11
    Sr. Apprentice
    Aug 2010
    Kansas City, MO
    what's the best way to get the oil out of the cylinders before cranking?
  2. #12
    take the sparkplugs out and then either crank it , or suck the oil out with a small oil change pump on each cylinder !!!
    1996 Suburban K3500 SLT DUALLY
    1988 Camaro RS 383 stroker LT1
    1992 32' Aero-tek Race Boat, 600 CI BBC
    WE CAN STICK A DIESEL IN ANYTHING
    SPECIALIZED IN CUSTOM CONVERSIONS OF ANY KIND
    Scott:glasses:
  3. #13
    Sr. Apprentice
    Aug 2010
    Kansas City, MO
    I've taken delivery, and learned it's a 93, not a 94, and 350k miles, not 400k (updated original post).
    Gave the inside a good vacuum, and was able to fairly easily crank the engine, so will probably skip the oil-in-the-cylinders step.
    Dropped a new battery in, put some new wipers on it, got a new air filter and radiator cap. Will work on the rest of the stuff this week.
    On the brakes, should I get them turned to clean the rust off, or just let that happen w/ the first drive (hopefully when that happens soon)...?
  4. #14
    Legend
    murdog94's Avatar
    Feb 2008
    Cloquet, Minnesota, United States
    Depends on how much you want to spend. Me i would drive a little off it off carefully. And if it still stops smooth then let her rip, and fix the other things and do the brakes last if they start to get bad.
    Mike
    Currently
    1997 Chevy S-10 Blazer 4X4 with 330K miles and counting (Hunting rig).
    2009 Saturn Aura XE (wifes car)
    2011 F-150 Crew 4X4
    "Hold it to the floor till you see God.... Then Brake!!!!"
  5. #15
    Jr. Engineer
    Aug 2009
    Muddy Creek, Va & Hunting Quarters NC
    congrats on your suburban!
    just an fyi did you know this is the suburbans 75th anniversary?
  6. #16
    Sr. Apprentice
    Aug 2010
    Kansas City, MO
    sounds like a plan on the brakes.
    Got new oil and filter in there (4 qts for now, will add more after I run it a bit).
    Got new spark plugs in.
    Tranny fluid looked/smelled fine, so will save that for later...radiator fluid seemed ok too, but that will probably be very next on list if/when it starts.
    Getting old gas out and new gas in is the next step...working on figuring out how to deal with and what to do with 20 gallons of varnish.
  7. #17
    Quote Originally Posted by mr24shoe View Post
    I would add little by little in to my lamower !!!!
  8. #18
    Legend
    murdog94's Avatar
    Feb 2008
    Quote Originally Posted by DAREDEVIL View Post
    I was thinking the same thing!, but with the size of my yard it would take me 10 years to use that up...
    But in seriousness i would try and find a drum (some waste disposal sites actually have them for this purpose) and empty it into that and dispose of it that way...
  9. #19
    Sr. Apprentice
    Aug 2010
    Kansas City, MO
    We have a hazardous waste collection facility here, just need to get it out of the tank and into something to transport. Worst-case, I'll buy a bunch of the 5-gallon gas containers, then resell them.
    So, getting the gas out...seems like there are 2 options.
    1) Pull the tank (seems like a pain).
    2) Pull the lines off the throttle body, and turn the ignition to on and let the fuel pump do the work (siphoning the fuel into cans of course). Is there risk here to damaging the fuel pump (sucking up debris or overworking it). I think I saw 3 hoses to the TB...which ones do I pull?
    I do have a new fuel filter to put in once I get some fresh gas in there too if that changes anything (don't know yet if I have to pull the tank for that).
  10. #20
    Legend
    murdog94's Avatar
    Feb 2008
    It wont really hurt the pump there is a screen on it keep out crap.. I would pull the line that goes into the fuel filter (mounted on the frame rail just below the drivers door on the inside of the frame rail that is) and get a hose to connect to that and pull it from there... As to the container that i why i was wondering if the waste facility might have an empty that you could use and drop off??? but connecting a line to that will allow you to get it out.. Or else run a siphon hose down into the tank (they make a siphon pump so no need to suck on it). and just take it out thru the filler neck.
Similar Threads
  1. 1994 GMC Suburban AC/Heater
    By Russ Suburban in forum General Chevy & GM Tech Questions
    Last: 08-18-2010, 01:07 PM
  2. 1994 Suburban Power Windows HELP/ please?
    By necrothropy in forum General Chevy & GM Tech Questions
    Last: 07-26-2010, 12:16 PM
  3. 1994 Suburban 2wd Transmission issue
    By humnbass in forum GM Powertrain
    Last: 02-07-2010, 08:56 AM
  4. Advice for my 1994 Suburban
    By Malsteem in forum Performance & Fuel
    Last: 08-07-2009, 01:03 AM
  5. 1994 suburban smog
    By turbo8 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 03-05-2008, 12:40 AM
