Thread: wheel bearings
    Default wheel bearings
    my 2005 Silverado needs new wheel bearings... or so I am told.
    My ABS light has come on within a month and a half of installing a suspension lift.
    The computer at my friends shop gave me a code for the front sensor.
    How do I find out if the sensors have just gone bad or if I do in fact need new wheel bearings.
    Also what are a good affordable set of wheel bearings to buy if I end up needing some.
    Thanks dudes
    2005 Silverado
    6 inch fabtech suspension lift
    17 inch Cragar Soft 8's with 4.5 inch backspace
    35 inch BFG All terrains
    2500 leaf springs in the back
    Check to see if the ABS line is rubbing and worn threw. We saw this alot with lifted trucks because with most lift kits you have to move the ABS lines and some people don't tie/strap them down correctly and they move when you turn your front wheels/tires and end up rubbing on the tire. If one of the lines is worn threw than theres you problem.
    thanks I will looks through it and get back to you
    decided to just replace both front wheel bearings. they are both no good.
    Doing it myself tomorrow
    If anyone has performed this operation and has any sort of advice before I get into it please let me know!
    thanks again guys!
    Also... would it be helpful to take pictures and post the procedure or is this an easy install?
    Aug 2008
    East of Branson, Missouri
    I'm sorry to not have gotten this to this post earlier. I just went through find kinda the same part you needed and got them very inexpensively.
    As for the pictures and procedure...the How-To Section could always use good write-ups and if you are so inclined I'm sure it would benefit others that are wanting / will want to do the very same thing you're about to do and will give them an idea of what is ahead of them.
    Steven
    "The Sarge"
    1999 Chevy Suburban LT- K2500
    7.4 454 Vortec, 4WD
    305/70/16 on Eagle Alloy
    hey springthing u said u know where to get cheap wheel bearings?! im going to replace mine on my 04 GMC and kinda straped for cash so the cheaper the better!!
    thanks for any help you can give me
    2004 GMC Sierra
    pace headers
    magna flow muffler
    gm performance intake
    305/70/16 Toyo MT
    16in hello maxx rims
    1987 Chevy K5 blazer
    stock 350
    4" lift 35s
  1. How to change wheel bearings/hubs 2500HD
    By cappyd892 in forum Chevy Silverado Forum (GMC Sierra)
    Last: 05-11-2010, 07:44 AM
  2. Replies: 1
    Last: 10-20-2008, 11:50 PM
  3. front wheel bearings keep going bad
    By chutton87 in forum General Chevy & GM Tech Questions
    Last: 07-04-2008, 01:41 PM
  4. Rear Wheel Bearings....DIY job?
    By ag90fox in forum Lifted & Offroad Suspension
    Last: 03-27-2008, 06:36 PM
  5. need help with wheel bearings
    By bart6180 in forum Chevy C/K Truck Forum
    Last: 06-29-2007, 01:45 PM
