    Angry 1998 Chevrolet Silverado 5.7 Code p0340 code help
    I started my truck today after having the battery disconnected for 3 day and got a CEL for P0102 and Camshaft position sensor circuit malfunction code. I checked all the wiring and it looks good can't find any issue. I also replace the camshaft position sensor to be safe. Cleared the codes, and boom. P0340 is right back. The truck is running find. It was missing badly prior to the sensor change but now runs great. I can't figure out why its still throwing that code. And to make matters worse next month my emissions inspection is due, and I'm flat broke. Please help. Thanks
    2007 Chevrolet Aveo 90K Miles
    1998 C1500 XCab 145K, Flowmaster Exhaust, Stock Engine, 4L60E trans, Amsoil thoughout.
    Jr. Engineer hundojoe's Avatar
    Feb 2010
    Elk River, Minnesota
    This may sound strange but your alternator might be causing the problem, if the voltage regulator is going bad the stray voltage will cause weird $hit to happen to the computer.
    1999 Silverado Regular Cab Short Box
    Black on Black, Line-X sprayed in bed liner
    5.3 with K&N CAI, Texas Speed 220/220 cam with 112 deg LSA
    Texas Speed computer Tune
    American Racing Headers with Cats
    4.11 gears front and back, with Eaton rear posi
    Flowmaster 40series true duals
    16X8 American Racing Nitros with 305/70/16 Goodyear MTR's
    285's in the pic
    If it ain't broke...........Give me a minute!
    Im not completely useless, I can be used as a bad example...
    I found the 20 amp fuse labeled engine 1 blows as soon as the key is turned on. There is no voltage on the 12 v supply to both the cam sensor or maf. Are they on this fuse??
    According to my wiring diagram (from Chiltons and downloaded free from the vehicle repair guides at autozone.com), those are both powered by a 20 A fuse called ENG-1, along with the O2 sensor heaters and the CANP solenoid. I would suggest you get a wiring diagram, and then it's time to find the short.
  1. 00 Silverado with code p1416???
    By jayfire in forum GM Powertrain
    Last: 05-17-2010, 11:10 AM
  2. 1999 Chevy Silverado Radio Code
    By chrissymouse in forum General Chevy & GM Tech Questions
    Last: 03-09-2010, 07:18 AM
  3. 2006 chevrolet tahoe getting code p-0446
    By SAMMIE1081 in forum General Chevy & GM Tech Questions
    Last: 03-05-2010, 05:27 PM
  4. Code PO753 - '02 silverado
    By 1980chevyman in forum GM Powertrain
    Last: 02-27-2009, 12:16 AM
  5. 02 Silverado p0443 code need troubleshooting help
    By kenwindsurf1 in forum General Chevy & GM Tech Questions
    Last: 08-19-2008, 05:27 AM
