    Default 99 GMC Suburban 260000miles Stubbles on accel.runs fine after engine heats up
    Truck has 5.7 vortec engine and when it first cranks up if you give it gas it stummbles or goes dead. It idles fine and after it runs for a few mins. it will accelorate with no problems. I have replaced o2 sensors, tsp sensor, heat temp sensor, air filter and fuel filter. I have ran sea foam through gas. We recently replace intake gasket. It has a ses code of P0420 any help would be greatly appreciated
    I asume a cracked distributer..I have the same and just ordered a billet one on the bay for 88 bucks , not the plastic one that is in it !!!!
    Scott:glasses:
    Quote Originally Posted by dirt2191 View Post
    A Code.....P0420.....is telling you that you that the Catalyst System Efficiency is below its Threshold....
    There are a number of items that could be causing this P0420 Code. ......The most common item is the catalytic converter itself is no longer functioning properly,
    The other likely item is the rear O2 (oxygen) sensor is no longer working properly,but as you have already re-placed them................Some of the other items to look at would include exhaust leaks,damaged exhaust pipes,damaged O2 sensor wiring/connectors and last a plugged catalytic converter.
    Sorry, did not read the code part !!!!!
    Last: 06-04-2010, 04:00 PM
  2. 1999 Suburban 5.7 Runs Rough-need some help.
    By jtriplett in forum GM Powertrain
    Last: 08-04-2009, 09:07 AM
  3. Need help, engine won't idle, runs rough
    By rickyg1 in forum Performance & Fuel
    Last: 09-09-2007, 09:44 PM
  4. 1987 GMC Suburban runs hot while towing
    By dec7777 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 08-01-2007, 11:47 PM
  5. Engine runs rough RPM's jump like it want to downshift
    By rminiger in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last: 01-02-2007, 09:36 AM
