    Default Air conditioning out in Yukon XL
    Hi, yesterday the AC stopped blowing cold. Fan works, compressor seems to kick on and the engine changes idle as a result, but only ambient air comes through. What to I check?
    63k miles, 2003 Yukon XL 2500 4x4.
    Sr. Engineer
    Aug 2009
    Virginia Beach, VA.
    Will it blow cold if you are moving and only warm when sitting still??
    I would get guages and check pressure....quick and easy first check.
    Maybe also go through your fueses and make sure you have not blown a fuse.
    first is to check pressures
    more than likely got a leak and lost the refrigerant.
    with ac running check your ac lines. cold side should be cold, hot side hot. check for frosted places wich would indicate a restriction
    GM TECH
    05 silverado shortbed
    Default Thanks for your replies guys
    This morning I found the A/C belt on the ground. It had broken. DOH! Well there's your problem! Pullies seem ok, so I'm just going to replace it.
    Appreciate the replies.
    Sebastian
    2003 Yukon XL 2500 4wd
    Sr. Engineer
    Aug 2009
    Virginia Beach, VA.
    LOL
    Yep, I would agree I would check the belt first. :D
    Good Luck with him.
  1. Air Conditioning Woes
    By jonsade in forum Chevy Silverado Forum (GMC Sierra)
    Last: 10-24-2013, 05:18 PM
  2. Air Conditioning Help
    By dan.hendrickson in forum General Chevy & GM Tech Questions
    Last: 05-01-2009, 04:32 AM
  3. Air Conditioning
    By blueZ71 in forum Chevy Silverado Forum (GMC Sierra)
    Last: 02-02-2009, 10:03 PM
  4. Air Conditioning Problem
    By Mr Eppy in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 09-21-2007, 10:47 PM
  5. Air Conditioning Problem
    By Mr Eppy in forum Chevy Silverado Forum (GMC Sierra)
    Last: 09-21-2007, 06:31 PM
