GM Truck Club
Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
  1. #11
    Sr. Engineer
    Aug 2009
    Virginia Beach, VA.
    Yeah, I agree 60 PSI is really high for the Low side.
    I would say your pressure switch on your Accumulator (maybe different on your truck compared to mine) as well.
    One other thing you can try is letting out some of the freeon...and then jumper the compressor to see if you can get it to ~45PSI
    Then see if it blows cold....
  2. #12
    I have not done this in a few years but it sounds like you have it about right. Go to another vehicle and put the gage on when the motor is off then start the motor and see what they are running. as long as they are both the same refrigerant you are ok. Dont worry about the rear air or the leak as long as it is real slow. It eventually will have to be fixed but a slow leak will not stop you from charging the unit. If you put the righ pressure when the motor is off and when you start it the pressures dont match the control vehicle you will have to check the evaperator coil for dirt, or fan motor. [Which should be on high.] Or the fan belt. The suction line [large line] should be very cold to the touch but not so cold that it frosts up.
    Good luck.
    Q
  3. #13
    Thanks much !!!!! and welcome to the site !!!!!!
    1996 Suburban K3500 SLT DUALLY
    1988 Camaro RS 383 stroker LT1
    1992 32' Aero-tek Race Boat, 600 CI BBC
    WE CAN STICK A DIESEL IN ANYTHING
    SPECIALIZED IN CUSTOM CONVERSIONS OF ANY KIND
    Scott:glasses:
  4. #14
    Quote Originally Posted by DAREDEVIL View Post
    Thank you and keep me posted on your progress.
    Q
  5. #15
    Thanks for all of your help , AC WORKS !!!!!!!!!!!!!!!!
    But ofcoarse now i have a new problem....hahaha, WATER PUMP !!!!! and how the hell do i get the fan off ??????? Is that thread on there left or standart ????
    ANY HELP WOULD BE AWSOME !!! LOL, damn truck,,,but i love it ..HEHE
    Scott:glasses:
  6. #16
    Legend
    murdog94's Avatar
    Feb 2008
    Cloquet, Minnesota, United States
    I believe it is left handed.. Not 100% but that is reverse of rotation...
    Mike
    Currently
    1997 Chevy S-10 Blazer 4X4 with 330K miles and counting (Hunting rig).
    2009 Saturn Aura XE (wifes car)
    2011 F-150 Crew 4X4
    "Hold it to the floor till you see God.... Then Brake!!!!"
  7. #17
    GOT IT !!!!!!!!!!!!!!! build me a nice tool , 2 holes and a little cutting and tool was done !!! BTW, the thread is standard rotation !!!! water pump works fine, all sealed up and AC is working aswell, changed to a billet distributer and everything works, only thing is it pops the code for the cam sensor and i dont know why..LOL
    after i delet it its fine , shut it off and back on, code showes ...MMMMMMMHHHHH ..oh well. !!!!!!!!
    Thanks for all of your help guys !!!! Anything i can help, just ask !!!!
    Scott:glasses:
  8. #18
    Jr. Engineer
    Aug 2009
    Muddy Creek, Va & Hunting Quarters NC
    In dealing with your AC problem. If you pulled a vaccum on your system while still having a leak then you pulled air and moisture into the system. you could have non condensables in the system causing the weird pressures. You need to fix the leaks, pull a really good vaccum and weigh the charge in. There should be a label under the hood stating the proper amount of refrigerant to put in. The rear AC could take upto an additional pound it will say on the label how much for just the front AC and the total for the front and rear. Also the low pressure switch will open at say 40# (not sure exactly what it opens at) then there is a differential before it closes again it maybe 60# again not exactly sure. It sounds like the switch is working properly. The main thing is a leak free , clean, dry system and weigh the charge in.
  9. #19
    Sr. Engineer
    Aug 2009
    Virginia Beach, VA.
    If you think you have a leak.
    Pull the vacuum and let it sit over night (24 hours) then put the guages back on and see if the vacuum is still there.
  10. #20
    NO LEAK....but a lot of **** in the system i guess..lol orfice tube is glooged up and changed it again...so now we see...i have know how now.....lol....so no problemo ...i can fill and all that in my sleep now...hahahahaha
    THANKS FOR THE HELP GUYS !!!!!!!!!!!!!!
    Scott:glasses:
Similar Threads
  1. AC Compressor
    By ruebeng28 in forum General Chevy & GM Tech Questions
    Last Post: 10-19-2009, 10:00 PM
  2. AC compressor
    By 99 Z71 in forum General Chevy & GM Tech Questions
    Last Post: 08-17-2009, 12:34 PM
  3. A/c compressor...
    By bUCKOLA in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 07-22-2009, 04:47 PM
  4. WTB Want to Buy A/C Compressor
    By thePhilster in forum General Classifieds
    Last Post: 06-24-2008, 07:32 AM
  5. FS: Air compressor
    By sbw9056 in forum General Classifieds
    Last Post: 01-29-2008, 10:10 PM
