Results 1 to 10 of 20
    Default AC pressure after changing compressor ????????
    Hi, i need to know how much pressure i need to fill in my 1996 Suburban !
    It has rear AC aswell.
    Any help would be very much apriciated .
    THANKS
    PS, maybe somebody knows how much goes in a 88 Camaro also ???? LOL ( wifes car )
    Scott:glasses:
    Sr. Engineer
    Aug 2009
    Virginia Beach, VA.
    Did you add in oil to the COmpressor as well??
    And put a vaccuum on the system??
    If those are in place, it should take about 3 - 4 cans easily.
    Do it with manifold guages, then you can watch the pressure build, and stop when it gets to 40 - 45 Low side.
    I don't believe the fact of having rear air makes a difference, but I could be very wrong on that assumption.
    ---------- Post added at 11:21 PM ---------- Previous post was at 11:19 PM ----------
    If you put on a new compressor and therefore the system is empty.
    If not done as well, change out the accumulator and the orifice tube.
    murdog94's Avatar
    Quote Originally Posted by MightyMax View Post
    X2... And yes 40 -45 MAX PSI depending on temp, which most of the R134a cans have a temp guide, on what the proper charge is for the ambient temp.
    Mike
    Currently
    2011 F-150 Crew 4X4
    Thank u all, but i have a 30# can and REAL gauges to fill the AC , also yes...oil in and vaccum done..-28 !!!!
    but @ 45 PSI my compressor wont even turn on.....at 65 it will work fine...??????????????????????????mmmmhhh
    Scott:glasses:
    murdog94's Avatar
    Seems that your high pressure switch has had it. And you are at 45PSI on the low side with the compressor running? not to be stupid just confused because i know that real guages allow for more accuracy. but you should have a 3lb system. So i would have installed 3lbs and gone from there. but that is why i am confused because your low side should be 45lb with the compressor engaged. If the compressor is off then it isnt sucking on the low pressure site to lower the system pressure.
    Mike
    Currently
    2011 F-150 Crew 4X4
    When the compressor is running it reads 55-60 PSI on low and about 250 on high !!!!after turning it off, it reads 75 on both !!! mmmmmhhhhh I'M LOST ..LOL
    Tomorrow i will bring it to an AC shop and let them figure this SH[T out..hahaha
    98 degree down here today ....sweting my a$$ off.
    Scott:glasses:
  1. AC Compressor
    By ruebeng28 in forum General Chevy & GM Tech Questions
    Last Post: 10-19-2009, 10:00 PM
  2. AC compressor
    By 99 Z71 in forum General Chevy & GM Tech Questions
    Last Post: 08-17-2009, 12:34 PM
  3. A/c compressor...
    By bUCKOLA in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 07-22-2009, 04:47 PM
  4. WTB Want to Buy A/C Compressor
    By thePhilster in forum General Classifieds
    Last Post: 06-24-2008, 07:32 AM
  5. FS: Air compressor
    By sbw9056 in forum General Classifieds
    Last Post: 01-29-2008, 10:10 PM
