    Aug 2010
    Sydney, Australia
    Default Silverado 2500HD Park brake adjustment??
    Hey All,
    I dont know anything about silverado's yet but I am learning, not much info over here in Australia though....
    I have a 2003 2500HD and when I press the park/E Brake it doesnt do anything, if the truck is in neutral it still rolls..... I am guessing it needs to be adjusted but am just wondering how..... Do I need to take the wheels off or is there something to access behind the hub or???
    Thanks all
    Lee
    2003 Silverado 2500HD 6.0L Vortec V8
    i have a 2000 1500 silverado and mine does the same thing. if anyone can help us out with this, it would be a great help
    for the 2500 the cables are on the framerail below the drivers door. I know this is where you disconnect it from the pedal and i believe adjust. I dont remember why but i know I have disconnected them there before.
    I have the disc rear end though so not sure if its different.
    David
    1960 Land Rover Series II 88
    2001 Pontiac Sunfire
    NRA Life Member
    Aug 2010
    Sydney, Australia
    I have the rear disc as well, I worked out that there is a rubber grommet behind the hub that you remove and you get a screw driver in there and turn a cog which pushes out the park brake more and adjusts it.... one grommet is on the top of the hub, the other is on the bottom of the hub (one side controls forward brake, the other side reverse brake)
  1. Parking Brake Adjustment? - 2006 1500 w/ rear drums
    By brtt485 in forum Lifted & Offroad Suspension
    Last: 08-02-2010, 01:31 PM
  2. Anti Lock Brake Parts 03 04 05 SIERRA SILVERADO 2500HD
    Last: 01-20-2010, 11:00 AM
  3. Parking brake cable adjustment
    By truckinon in forum Lifted & Offroad Suspension
    Last: 03-17-2008, 12:33 AM
  4. Brake proportioning valve adjustment?
    By Sabre7 in forum Lifted & Offroad Suspension
    Last: 03-03-2008, 08:54 AM
  5. 2002 Suburban Parking Brake Adjustment
    By Tom Evans in forum Lifted & Offroad Suspension
    Last: 02-23-2008, 10:11 PM
