    Default 1989 5.7 timing chain R & R
    Greetings, anyone have a good set of instructions for the timing chain R & R on my Sub?
    What would be the best manual to buy, if i have to get one?
    Thanks,
    1989 Chevy V1500 Suburban 4X4, long tube headers & xover pipe. w/1985 350 4bbl.
    2002 Silverado 1500 5.3L Ext. Cab
    2005 Wrangler Rubicon 4.0L
    1990 Miata
    I basic Haynes or Chilton manual should give you enough data to change it. Pay careful attention to the instructions on setting the engine to cyl #1 TDC before doing the work and the alignment of the dots on the gears on installation.
    Are you sure you need to change your timing chain? They usually don't stretch or break.
    Christopher
    I have several posts regarding the excessive pinging on my sub. I pulled the timing cover off and at TDC (the finger in the #1 hole method) the cam looks like it is 180 out. Just wanted to verify what is going on there.
    Master Mechanic rustyk2's Avatar
    Mar 2010
    South Carolina
    Are you sure that you are on the compression stroke? each piston tops out twice, once on compression stroke the other on exhaust stroke. If you have to, pop the valve cover and check the rocker arms on #1. if both valves are closed its the compression stroke. Both Haynes and Chilton's books will have the steps needed to change it out.
    Dana South Carolina
    1986 V20 Suburban
    1988 V20 Suburban
    1995 Camaro convertable
    2003 Trailblazer LT
    :sign0196::wink2:
  1. 96 Suburban timing chain
    By DeadHead in forum GM Powertrain
    Last: 09-01-2010, 07:34 AM
  2. Timing Chain Marks
    By bigbluesub in forum GM Powertrain
    Last: 08-29-2010, 08:13 PM
  3. timing chain
    By 07suburban in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 06-01-2010, 11:50 PM
  4. Noise Behind Timing Chain Cover
    By captluigi in forum GM Powertrain
    Last: 12-26-2008, 07:43 PM
  5. Timing Chain??
    By cchas14 in forum General Chevy & GM Tech Questions
    Last: 04-12-2008, 08:43 PM
