Results 1 to 5 of 5
    SpamAssassin
    Cableguy has a reputation beyond repute
    Oct 2006
    Ontario,Canada
    1 Post(s)
    1 Thread(s)
    Default Tire Maintenance Tips
    Author: Joe Stanton
    Periodically checking your tires is strongly recommended to ensure full safety to you and your own car. Tires are fundamental for our safety but if you ask someone how does he care of his tires he'll probably won't know what to answer if not "I just replace them when they're worn out".
    This is not the best you can do for your safety: paying attention to your tires is just a matter of habits and doesn't cost you a single buck, you should really be doing it.
    This is what you should do:
    1. Tire Pressure
      Tires should always be inflated as suggested on the service book of your car. This will also make your tires last longer: driving with underinflated tires reduces the contact area between the thread and the ground because the central part of the thread is pushed upwards so the edges will wear faster, moreover an underinflated tire causes high fuel consumption and produces vibrations and noise. Keeping your tires overinflated will cause the central part of the thread to wear faster. A correct inflation grants you and your passengers the best safety in any standard driving condition. Tire pressure should be checked each 2-4 weeks and before any long trip.
    2. Tire Wall Damages
      You should often check if your tires have damages on the walls. These damages happen hitting the pavement with a tire while parking. This can cause the tire wall to present bubbles and cuts. If your car has been exposed to hot and cold weather you could also find cracks: you might find cracks even if your tires are old; old tires should be replaced as a safety measure even if they have enough thread left.
    3. Tire Wear
      Make sure that your tires wear regularly: rotate the steering wheel to the extreme right or left and check if both the edges are equally worn. In case you notice tires are more worn on the inside or outside go to a garage and let them know, they'll fix your tires alignment.
      Tires have wear bars: when the tread lugs are worn to the point that the wear bars connect across the lugs, your tires are fully worn and you should take them out of service.
    4. Tire Rotation
      Most tires have a rotation direction shown on the tire wall, make sure your mechanic mounted them correctly
      Tires are made to rotate in that direction, opposed rotation could be dangerous in case of rain or high speed.
    5. Rotate Front and Rear Tires
      Front tires wear quicker than rear ones due to steering while parking and braking weight effect. This happens even more on front traction cars. Rotating them will make them last longer and in better shape, otherwise you'll have your front tires fully worn and your rear ones still in good shape. You can to this yourself or go at your usual garage and have them do it for you.
    6. Tires Storage
      If you own several tire sets you'll always have some tires to store somewhere. Wrong storage can damage your tires. Store your tires in horizontal stacks. If you store them vertical they will tend to get oval shape.
    As you can see there are few things to care of regarding tire maintenance, I hope you understand the importance of tires in good conditions: imagine if one of your tires exploded while you're driving on the highway and think that you can do something to prevent it.
    Jamie
    2007 Ford E250(Work van) (Ya, Ya, shut up!)
    1996 GMC Sierra SLE 1500 5.7L/4L60E
    http://www.thefundumpster.com
    Legend TrailLeadr has a reputation beyond reputeTrailLeadr has a reputation beyond repute
    Jun 2005
    Coventry, Rhode Island
    2 Post(s)
    1 Thread(s)
    What nothing on siping?
    Patrick
    Rhode Island
    SpamAssassin
    Oct 2006
    Ontario,Canada
    1 Post(s)
    1 Thread(s)
    Quote Originally Posted by TrailLeadr View Post
    Ya when you go to the shop to get them installed they "sipin' " your wallet...oh my goodness thats funny!
    Jamie
    SpamAssassin
    Oct 2006
    Ontario,Canada
    1 Post(s)
    1 Thread(s)
    Ok maybe that wasn't funny...I'll stop
    Here's how siping works:
    Siping cuts slits, called sipes, at 90° angles across the tread, providing thousands of gripping edges for better traction and stopping power. Wear-robbing heat and hydroplaning are also minimized.
    Check out the information below to find out how you can improve your traction in poor weather driving environments. Scientific Tests Confirm It
    Improved traction up to 200%! An independent company tested the siping effect on starting, stopping and driving traction while driving on medium snow pack.
    Repeated tests proved that siping increased starting, stopping and driving traction by as much as 200%!
    Improved Braking
    Research has shown that the most effective braking power occurs immediately prior to losing traction. Siping extends the window allowed for maximum braking power by giving the existing tread a helping hand. In the examples above notice how the siped tire has dozens more gripping edges. These micro edges reduce the distance needed for braking on wet and icy roads.
    Better Traction
    The tread surface on your tire is made up of many smaller surfaces know as “Tread Blocks”. The reason for so many surfaces is especially important when it comes to icy or wet road conditions. The Tread Blocks get their gripping power not from their many smooth surfaces but from the more numerous sharp surrounding edges. Siping improves the job started by your tire manufacturer by providing more of these gripping edges.
    Smoother Ride
    New asphalt is relatively smooth but time and wear exaggerates the coarse texture of the road's surface causing your tires to absorb most of the impact. Siping gives your tires a Micro-Flexibility reducing the wear on your tires' carcass and sidewalls. This effect not only increases tire life but will result in a smoother ride.
    Jamie
  5. #5
    Jun 2005
    2 Post(s)
    1 Thread(s)
    much better. I personally think all tires should be siped, well maybe not all, but most.
    Best upgrade you can give your tires, and only costs you the tool, and one day out of your weekend.
    Patrick
    Rhode Island
Similar Threads
  1. oil maintenance
    By pmarc in forum Chevy Truck Forum
    Last Post: 06-29-2009, 12:15 PM
  2. Tire Pressure tips
    By sheep in forum Wheels & Tires
    Last Post: 10-13-2008, 02:06 AM
  3. maintenance
    By dcjones13 in forum General Chevy Tech Q&A
    Last Post: 03-07-2008, 06:18 PM
  4. Tire Maintenance Tips
    By Cableguy in forum The Coffee Shop
    Last Post: 05-11-2007, 10:46 PM
  5. Goodwrench Says Proper Spring Tire Maintenance a Must
    By Steve in forum Automotive News
    Last Post: 05-05-2007, 08:56 AM
