GM Truck Club
Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
  1. #11
    ok, new update on the SC, a m90 WILL work on the 3.4l however..it will NOT bolt up to the 3.4l lower manifold and a 3.8l manifold will not fit on a 3.4l (3.4l=60degrees, 3.8=90degrees) I will have to find a shop to CNC a custom manifold...which means I better get to the drawing board to design and measure out a custom manifold.(unless I can find a CMM machine, or a way to modify the stock manifold) but modifying the stock manifold will cause the blower to stick above the hood, calling for a cowl or cutout hood, ruining the plan for a sleeper.
    the stock MAP sensor will read up to 14.7 psi so thats not a problem (I plan to run 6-8 psi on partial stock internals for now).
    the stock TB will also work with the m90
    Injectors from a 02+ Trailblazer are a direct fit on the 3400 (maybe someone here has some)
    and as for the labtop tuning program, HPTuners supports the v6 alero (EFILive only supports the 2.2L) and its a few hundred cheaper than EFILive.
    I will try to keep updates coming, most of my money is coming in sept 30th, then I can get a bit more figured out
    exhaust is coming first though...catback, highflow cats, super 44s...may also look into Corsa
    Justin
    1990 Silverado Stepside
    2003 Olds Alero-
    64,XXX
  2. #12
    Legend
    murdog94's Avatar
    Feb 2008
    Cloquet, Minnesota, United States
    Glad you got that much figured out. as i said i never got as far into it because of a little brown deer, and i started to focus on making more power in my trucks.
    Glad its all working out for you.
    Mike
    Currently
    1997 Chevy S-10 Blazer 4X4 with 330K miles and counting (Hunting rig).
    2009 Saturn Aura XE (wifes car)
    2011 F-150 Crew 4X4
    "Hold it to the floor till you see God.... Then Brake!!!!"
Similar Threads
  1. GM Olds Chevy or Pontiac DIC(Drivers Info Center) Unit.
    By ChevyFan in forum Chevy Parts eBay
    Last: 08-16-2009, 04:30 PM
  2. How about this for a 4yr olds birthday
    By tbplus10 in forum The Coffee Shop ~ Chit Chat
    Last: 04-03-2008, 07:30 PM
  3. Olds Achieva
    By Cableguy in forum Other GM Cars
    Last: 05-12-2007, 10:07 PM
  4. 1986 Olds Cutlass
    Last: 05-12-2007, 09:39 PM
