Results 1 to 9 of 9
    Default Shocks or Torsion Bar Adjustment
    I have a 99 Z71 Extended Cab and my front bumper stops are sitting on the lower control arms and was wanting to know if new shocks would correct this problem or can I raise the torsion bars? If I do raise the torsion bars, do I need to get an alignment afterwards? Thanks.
    Welcome to the club. It sounds like the torson bars are already adjusted to the max, thats why there hitting the lower control arms. If you have stock length shocks than there bottoming out. You should crank the bars down some. Look at the torson bar adjuster bolts and most likely there are screwed all the way in. Do you have over size tires?
    I have 265/75/16's on there. Not sure what the stock size is because the sticker is missing from the door jam. As far the torsion bolts, they had still had some threads showing, so they are not screwed all the way into the cross member. Would worn out shocks make it sag that low to have the bumper stops touch?
    No, worn shocks won't make the truck sag that much. You say the t/bar adjustment bolts have a few threads showing. Whats a few threads?
    Sorry it took so long to reply. There is about 3/4" from the crossmember to the bolthead. I lokked at my neighbors '05 Z71 and his bump stops were on the lower control arm. He said he still had the original shocks and has not touched the suspension since he bought it.
    Aug 2010
    Sydney, Australia
    Im asking this same question with my 2003 2500HD, my front lower control arms are on the bump stops too... but I think I still have a fair bit of thread on my torsion bolts so I am going to try to wind them up a bit this afternoon and see if that lifts them off the bump stops a bit...
    2003 Silverado 2500HD 6.0L Vortec V8
    Aug 2010
    Sydney, Australia
    Hey All,
    I have wound the torsion bar bolts in which has lifted the bump stops slightly off the lower control arms, however as soon as you sit in the car the bump stops go back on the lower control arm...
    I have attached some pictures of the 2 bump stops and the torsion bar bolts..
    Can anyone advise what I need to do...
ID:	21030Click image for larger version.
ID:	21031Click image for larger version.
ID:	21033Click image for larger version.
    Aug 2010
    Sydney, Australia
    anyone able to help?
    Newbie
    Oct 2010
    Grantsburg,WI Gateway to the swamps of Minnesota
    I'm going through this as well. 03 Suburban. Set my "Z" height to 4.7, one bump stop is resting on control arm the other has an inch gap. Drives bad, dealership said I set it right. Seems to me it should be one way or the other, i'm guessing slightly on the control arm. Torsion bars are turned up with about 2 threads showing.
  1. tpms adjustment
    By SOAP2500HD in forum Lifted & Offroad Suspension
    Last: 12-30-2009, 08:15 PM
  2. window adjustment
    By gargoyle725 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 07-29-2009, 06:26 AM
  3. torsion bar adjustment
    By badbowtie12 in forum Chevy Silverado Forum (GMC Sierra)
    Last: 03-25-2009, 03:18 PM
  4. tie rod adjustment
    By skipbeau3790 in forum Member Introductions
    Last: 11-02-2008, 10:36 AM
  5. Fender Adjustment
    By Trex in forum Chevy Colorado Forum (GMC Canyon)
    Last: 05-12-2008, 03:48 PM
