Page 1 of 3 123 LastLast
Results 1 to 10 of 23
    Default Level Kit Pic Request
    I have been running the ReadyLift 1.5" level kit with factory 265/70 R17's and contacted ReadyLift about up grading to the 2.25" kit. I talked to the rep found out that the 2.25" kit was just the 1.5" with an extra part on the bottom of the strut. I ordered this part and wanted to know how a NNBS 1/2 ton looks with 2.25" level kit running 265's. I plan on getting 285's, but just bought GY DuraTrac's in a 265 so it will be many miles before I get 285's.
    Pictures and or any advice on running a 2.25" level kit with 265's would be appricated.
    Thanks!
    yo man, i have an 07 silverado and i got the Rough Country 2" leveling kit which is a U shaped spacer that goes where the strut is bolted to the lower control arm. here's a pic
    '07 LT Z71 5.3 | Rancho | Falken | 6k HID | Fuel Offroad
    That looks damn good! I am not so worried about running the 2.25 with stockies now. When you park on a flat lot does it seem you have reverse rake? I got the tape out yestereday and looks like I will be 3/8" higher up front.
    The kit I put on was a 2 piece design that went above and below the strut. It was a 2.5 in. from top gun customs. It looked great until I put my camper shell on...now it looks slightly like a reverse rake. I measured it once and I think it was only 1/4 or 3/8 inch, but it bugs me. I'm thinking about putting on the readylift 2" or 3" rear blocks to raise the back. I could just take out the upper plate on top of the strut, but I like the height the front is at now. I'm not running the tire size you asked for (I've got stock 20's), and I'm not sure if the rake is different for 2WD, but maybe you can get an idea.
    -Sal
    Desert Brown Metallic
    When it isl "your" truck it is always the small things that bother you. Sal, I think your truck looks great, but you see it everyday and you can really tell the rake difference when someone else might not have a clue. I keep telling myself it is just 3/4 of an inch more, but then I will tell myself I should hold off till it's time for 285's. Decisions decisions.
    Sr. Apprentice Fan45acp's Avatar
    Aug 2009
    Marshall,Tx. USA
    Here are a few pictures of my 2009.I installed a Rough Country 2" Level.Easy and good results.
    Thanks for the compliment, Ajarman. And you're right, no one else seems to notice but it drives me crazy. Only when I'm loaded down will someone say anything. The 2.25" shouldn't be as bad though, and like I said, it was fine before the weight of the camper shell ( and the air tanks, and the horn, and my tools....) sank it down.
    -Sal
    Quote Originally Posted by ajarman View Post
    Well I only have the 2" kit so it doesn't have any reverse rake. But I don't think the 1/4 " more from the kit that you have won't make that big of a difference
    "If orange juice had armpits, maybe."
    -the wife in reference to the smell of JOOSE
    Thanks for the help guys! I think I am just going to have it put on once it comes in and just hope Santa drops off some 285's in 3 months!!
  1. ReadyLift - front level kit or SST lift/level kit
    By JW2007-6.0 in forum Lifted & Offroad Suspension
    Last Post: 03-13-2010, 02:07 AM
  2. Pic Request plz
    By NJclassic in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 01-25-2009, 10:12 PM
  3. pic request
    By 1slols1 in forum Lifted & Offroad Suspension
    Last Post: 01-19-2009, 10:59 PM
  4. pic request
    By zach45 in forum Lifted & Offroad Suspension
    Last Post: 08-10-2008, 12:04 AM
  5. on the level, really!!! Level headed?? HUH?? [Expired Topic]
    By army dude in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 01-25-2007, 10:02 PM
