    Default check engine light
    my 1997 suburban has a code p0300,p0151,p0131 .i need help how to fix the problem .
    All three codes could have a single cause. I'd probably start by investigating why the O2 sensors are reporting lean. "By the book" one usually starts diagnosing O2 sensor codes by checking the fuel pressure to make sure the fuel system is running right. Look for any significant vacuum leaks. I might pull the spark plugs to see if they indicate whether the engine is running lean or rich.
    Talking check engine light
    i will start with the O2 sensors thanks for the tip. will keep you posted
    thanks MrShorty
    mrShorty ,i found a exhaust leak, i fix it and the check engine light has not come on.
  1. Check engine light
    By old teacher in forum GM Powertrain
    Last: 05-17-2010, 08:03 AM
  2. check engine light
    By DTRJAG in forum GM Powertrain
    Last: 11-10-2009, 05:06 PM
  3. Check Engine Light?
    Last: 06-29-2009, 09:58 PM
  4. Check Engine Light
    By Nevada Born in forum Chevy Trailblazer Forum (GMC Envoy)
    Last: 12-27-2008, 01:18 AM
  5. Need Help With Check Engine LIght
    By Jaystahoe in forum GM Powertrain
    Last: 07-23-2007, 10:11 AM
