Results 1 to 10 of 14
Thread: Engine Swap
    Default Engine Swap
    I was thinking about doing an engine swap in my truck. I have a 5.0 Vortec right now. I was thinking about swapping it for a mildly built 5.7. Has anyone done this before? Can this be done in this truck, with the ECU, and what would I have to do to my ECU to make it work right?
    Master Mechanic rustyk2's Avatar
    Mar 2010
    South Carolina
    Should be fairly strait foreward, same block, everything will line up, just might need a re-tune on the ecu or get one from a 350.
    Dana South Carolina
    1986 V20 Suburban
    1988 V20 Suburban
    1995 Camaro convertable
    2003 Trailblazer LT
    :sign0196::wink2:
    murdog94's Avatar
    as long as you maintain a stock outward 5.7L vortec (meaning sensors etc) then it is a plug and play affair! And yes depending on how built you go you will need a custom tune, if you go with a stock or close to stock 5.7L then you will just need a 5.7L ECU for a manual tranny.
    Mike
    Currently
    2011 F-150 Crew 4X4
    I was also thinking about putting an LS motor from a newer model truck in, what would be the best way to go?
    Aug 2010
    Channahon, IL
    The iron block 6.0L is practically indestructible and easy to modify. Obviously, you'll need the electronics for it (ECU, harness, etc.) and you will also either need a trans adapter plate to mount to your trans, or a trans from the donor vehicle to match. Also, the engine mounts need to be changed. If you plan it all out ahead of time, it may seem like a lot of work and time, but is worth it. This is the new way to go. Good luck with your decision!
    440 HP 383 + 150 shot = fun weekend!
    I thought about the 6.0 but I'm not real sure about what I would like to do yet. There are too many options.
  1. engine swap
    By 1990burb in forum GM Powertrain
    Last: 09-02-2010, 10:31 PM
  2. Engine Swap
    By Lgriffi in forum General Chevy & GM Tech Questions
    Last: 02-06-2010, 10:37 AM
  3. engine swap
    By dboii313 in forum GM Powertrain
    Last: 05-03-2009, 05:55 PM
  4. engine swap
    By sdrewes72 in forum Chevy C/K Truck Forum
    Last: 03-25-2009, 02:43 PM
  5. 5.0 to 5.3 engine swap
    By motogizzo in forum General Chevy & GM Tech Questions
    Last: 04-20-2008, 12:33 PM
