    Default Transmission Swap
    I did a search on the site to see if this was a thread before but i didn't find anything. I wanted to know if it was possible to swap a new silverado's 6 speed auto into my 05 5.3L 2wd silverado.
    Never heard of the swap, sounds like a good one. I would think at the least you have to replace/modify the trucks ecm.
    Thats what i was thinking. Maybe give me the ability to stick a lower rear gear in it but keep highway mileage the same.
    Are both trucks 2wd? You will need to modify the transmission braces though, they changed with the new body style i believe. You will need to change the your ecm. And i also believe there is a difference in length of the transmissions so a new drive shaft might be in store. I don't know the physical size of the new transmissions compared to your body style, but the exhaust might be in the way when it goes under the transmission.
    Take a look under a truck like you wana swap. Who knows! Good luck!
    www.youtube.com/ippielb
  1. Transmission Swap?
    By jeremytn86 in forum GM Powertrain
    Last Post: 04-14-2010, 06:50 AM
  2. Transmission Swap
    By Jarrett in forum GM Powertrain
    Last Post: 04-01-2010, 05:07 PM
  3. Transmission swap ??? Will it work ???
    By chipmunk222 in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last Post: 06-27-2009, 10:07 AM
  4. 95 chev transmission swap?
    By bcgmcman in forum GM Powertrain
    Last Post: 04-07-2009, 07:20 PM
  5. Transmission swap
    By John in forum General Chevy & GM Tech Questions
    Last Post: 05-16-2008, 02:37 AM
