    Default 2007 Crew cab 2wd, Lift and shock question?
    Hey guys.. thought it would be a good idea to join a forum so I can find answers to my many questions! I have a 2007 Silverado 1500 crew cab 2wd new body style and I would like to lift it 4.5 inches. The question is how high can I go before I would need new shocks? Many lift kits come with the choice to have shocks included or not at all. Any input would be helpful, thank you!
    First, welcome to the GMTC. Now, I would say anything over a 2.5" leveling kit and you are going to want the extended shocks. And I'm sure some will tell you even with just the leveling kit it's a good idea to swap out the stock shocks.
    2002 Chevy 1500 Ex-cab Z71: 5.3L, auto 4, shorties, hi-flow cats, true dual 2.5" straight pipes, AirAid intake, TBS, Platinum plugs, 8.5mm wires, programmer, 3in w/ 33s, also has the composite bed
    2010 GMC 1500 Crew Cab Z71 w/ All Terrain package: 5.3L, auto 6, 2" Zone leveling kit, AirAid Jr. Intake Kit
    Thank you very much! I was leaning more towards getting the shocks just to be safe anyways..
    mfleetwood's Avatar
    Jul 2010
    Denver, CO
    Welcome!!! I have some experience with this, as I did a ton of research prior to me recently installing my kit, and found that you will probably either need to replace your shocks or find a kit that uses shock extension mounts. However, most recommend replacing the shocks. That said, this is about the only experience I have with suspension items, so I would not put too much weight on my statement.....definitely see what others have to say.
    TIRES:
    BFG All Terrain KO 315/70/17
    You really need longer shocks or shock extensions with just a leveling kit so with a 4" lift you definetly need longer shocks. The reason most lift companies make the shocks a option is that some people what to run a differant type shock or a dual shock set up. Which lift kits have you looked at?
    murdog94's Avatar
    ********thread moved here***********
    If you have any questions about the move you can feel free to PM me.
    Mike
    Currently
    2011 F-150 Crew 4X4
    Sr. Engineer Sam_A's Avatar
    Jul 2010
    Hattiesburg, Mississippi, United States
    Welcome to the club!
    I'm running truck on stock suspension, so I can't really give you any good advice on the lift, but there are a lot of people here who can.
    2003 Chevy Silverado 2500HD LT 4x4, Crew Cab
    6.6L Duramax Diesel (LB7) with an automatic Allison 1000 5 speed.
    Spray-in bed liner, S&B Air Filter, Homemade CAI ram scoop, ball hitch for Gooseneck
    Black toolbox, metallic-black bowtie, 5.5" NV-200C Bumper Off-Road lights behind a blacked-out grille
    285/75R16E BFG A/Ts
    Future Upgrades: Exhaust, CAI, programmer, intercooler, torque converter
  1. new member
    By Rdyiirun in forum Member Introductions
    Last Post: 02-22-2010, 08:58 PM
  2. New member, but not new to GM
    By Mumbles in forum Member Introductions
    Last Post: 02-19-2010, 02:55 AM
  3. New member from SC
    By 53jimc in forum Member Introductions
    Last Post: 01-15-2010, 09:20 PM
  4. new member from IN
    By nella in forum Member Introductions
    Last Post: 03-27-2009, 04:51 PM
  5. New member for TX
    By jlh0324 in forum Member Introductions
    Last Post: 03-26-2009, 06:46 AM
