    Unhappy Engine light after replacing head gaskets??
    i just replaced my head gaskets on my truck and now my engine light is on and the engine sounds a bit sluggish...i put everything back the way i took it out and i cant figure out why its doing this??? any help is appreciated..thanks.
    2004 Chevy Silverado LS Ext Cab
    auto, 4.8L, 190 HP (dyno'd)
    murdog94's Avatar
    You will want to have the codes pulled for the check engine light. that honestly is the best place to start and takes all of the guessing out of it. I dont know how they handle auto parts in germany (like we have large auto parts store chains here) but if you can go to an auto parts store and they have an On Board Diagnostics 2 (once again not to sure what germany calls certain things) scanner then you can pull the codes and go from there.
    Mike
    Currently
    2011 F-150 Crew 4X4
    i appreciate the response murdog...i found out what was wrong when i took a closer look :( i put everything together at night...so when i rechecked everything in the day, i found that i forgot to pug in my driver side harness to the coils...so she was running on 4 cylinders...i felt really stupid for overlooking that small thing...hope this might help someone else though..lol...thanks.
    Jun 2006
    Boy, do I get that. It is 5x harder to do work at night!
    Were you doing head gaskets(huge nasty job), or intake manifold gaskets(nasty but not so huge)?
    Charlie
    1998 suburban-
    1/2 ton
    199500 miles
    River
    Ridge,LA
    both..lol..replaced everything from the heads up pretty much...and a few others..head gaskets, intake gaskets, vavle cover gaskets, thermostat, fuel injector o-rings ( upper and lowers)..just to name a few
  1. Replacing brake light switch
    By zuper8 in forum GM Electrical Tech
    Last: 09-15-2010, 11:33 PM
  2. Replacing an engine
    By mjn030 in forum Chevy Silverado Forum (GMC Sierra)
    Last: 04-08-2010, 10:22 AM
  3. Replacing 2007 yukon head lights
    By RILEYMAN1 in forum Member Introductions
    Last: 07-22-2009, 08:37 PM
  4. replacing engine in 00 Z71 thinking of ls2
    By bhump in forum GM Powertrain
    Last: 12-01-2008, 11:50 AM
  5. Engine Gaskets
    By makthenif in forum GM Powertrain
    Last: 06-26-2008, 10:19 AM
