    Default 95 Tahoe, high idle, trans starts out in 3rd gear.
    I am in a quandry. My 95 Tahoe has been parked for about 90 days. Prior to that it ran and drove like a new truck. Now it starts right up, but idles in park at 1200-1300 rpm. in gear it is right at 1000 rpm. The idle is a bit on the rough side. It is silky smooth at cruise speed.
    I see the "check engine" light is on, but I can't get a code.
    The biggest problem is that when the gear selector is in "D" the trans starts out in 3rd gear. If I manually drop it all the way to low it starts out in 2nd. Prior to retiring the truck I did a trans service with synthetic fluids and an oil change along with a complete tuneup. I did drive the truck for a couple of days after the service and all worked great.
    Any ideas out there?
    Sr. Engineer
    Aug 2009
    Virginia Beach, VA.
    I would look in the area of the TPS (Throttle Position Sensor) or the IAC (Idle Air Control)....
    But the TPS would be my first look I think.
    Is a TPS signal relative to the transmission?
  1. high idle/ high engine compartment heat
    By lynx in forum General Chevy & GM Tech Questions
    Last Post: 09-05-2010, 03:03 PM
  2. Low idle speed when in gear?
    By artlock in forum Performance & Fuel
    Last Post: 07-29-2010, 10:34 AM
  3. 1999 Tahoe high idle
    By ffcmckinney in forum GM Powertrain
    Last Post: 03-30-2010, 01:15 PM
  4. high idle
    By jeroen in forum General Chevy & GM Tech Questions
    Last Post: 02-07-2010, 04:06 AM
  5. sporatic idle while in gear and cold...
    By Cros89 in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 02-20-2009, 09:12 AM
