    Default Wheel Backspacing?
    I've always been a bit confused on the back spacing and offset on wheels. I'm looking at getting some 20x10 wheels and not sure what offset the wheels should be. I'm planning on putting on a 325/60/20 tire if that makes a difference. Anyone know much about this?
    2006 Duramax LBZ
    Edge Evo
    4'' Diamond eye to 6'' tip
    Lots of work left to do!
    stephan's Avatar
    Far West, Oregon USA,
    I found this in the archives a few days ago. It should answer all your ques on wheels. It's excellent
    http://www.gmtruckclub.com/forum/sho...r-Measurements
    3" susp. lift kit "shadetree"
    Thanks that did answer all my questions! That was a freakin sweet diagram
    Quote Originally Posted by ntbush83 View Post
    Backspace and Offset are tied together
    Measuring Wheel Offset To calculate offset you'll need the following measurements:
    .......Wheel backspace Wheel Width Wheel Center line (outboard flange to inboard flange measurement.
    ......Wheel center line from Wheel backspace to get offset......If backspace is less than the wheel center-line the offset is negative....If backspace is greater than the wheel center-line the offset is positive.
    On the Below Link.....On the Left Side,you want to enter your Rim and Tire Size you have on your truck Now......and then on the Right Side enter your Rim and Tire Size,
    It will show you the difference from your Stock Rim & Tire Set-up,to the Rim & tire set-up you want to put on,
    http://www.rimsntires.com/rt_specs.jsp
    Edit....Sorry Stephan,While I Was writing-up my reply....you had replied,did not mean to do that.....
    stephan's Avatar
    I saw that same article in a Super Chevy mag about 6 years ago, but loaned it to my friend & never got it back so was happy to find it here at GMTC.
    ---------- Post added at 02:23 PM ---------- Previous post was at 02:16 PM ----------
    No Worries Heartbeat
    I am such a slow typer that many times there are 2 or 3 posts appear while I am typing my answer.
    [/FONT][/QUOTE]
  1. Replies: 23
    Last: 07-02-2011, 01:12 AM
  2. wheel and backspacing question
    By bacol14 in forum Lifted & Offroad Suspension
    Last: 06-09-2010, 01:37 AM
  3. 07 leveled wheel backspacing
    By rangercliff in forum Lifted & Offroad Suspension
    Last: 05-25-2010, 08:11 PM
  4. lifted s10 or sonoma wheel backspacing
    By black98noma in forum Lifted & Offroad Suspension
    Last: 05-15-2010, 11:27 PM
  5. wheel backspacing help!
    By tallhoe in forum Lifted & Offroad Suspension
    Last: 05-22-2009, 04:21 PM
