    Default Antifreeze smell under hood but no visable leak
    Ok guys this is what I have; I picked this truck up at an auction a few weeks ago, it has 156,000 miles on it but it runs great. I'm noticing an antifreeze smell from under the hood & I can't seem to find any visable leaks. It does have the red coolant in it, here's the list of stuff I looked at trying to figure this out:
    Starts and warms up fine (stays just under 210), heater works fine too.
    Pass floor dry
    No apparent antifreeze smell in exhaust
    Oil looks normal (oil pressure is at 40 at idle)
    I've read that the 2001 - 2006 5.3's have head problems but considering mine's a 1999 I don't think this is the issue (at least I hope not). Any thoughts?
    2012 Chevy Silverado 1500 LT
    Z71 4X4
    5.3 L
    HD Cooling & Trailering
    murdog94's Avatar
    Well you may have a faulty Radiator cap, also there is a vent (hence possible bad cap) also if your not using coolant that is where i would start.
    I did have a 2002 that had a clamp fail, and had a slow leak, till i found the broken clamp.
    Mike
    Currently
    2011 F-150 Crew 4X4
    I have had a radiator leak that was small enough that the coolant wasn't dripping but once it was hot it would begin to release steam. That's why i could smell it but not see it. might want to try a SMALL amount of stop leak.
    2002 Chevy 1500 Ex-cab Z71: 5.3L, auto 4, shorties, hi-flow cats, true dual 2.5" straight pipes, AirAid intake, TBS, Platinum plugs, 8.5mm wires, programmer, 3in w/ 33s, also has the composite bed
    2010 GMC 1500 Crew Cab Z71 w/ All Terrain package: 5.3L, auto 6, 2" Zone leveling kit, AirAid Jr. Intake Kit
    Quote Originally Posted by KWG08VMI View Post
    I had the same thing happen but mine was the water pump gasket.
    03 Chevy Silverado 1500 ext cab Z-71
    79 AMC Spirit GT
    77 Olds cutlass supreme
    I agree with murdog94. It's most likely your radiator cap.
    Thanks guys, I'll start with replacing the coolant recovery tank cap as recommended and report back in a few days. Thanks
    Z71 4X4
    5.3 L
    Feb 2009
    FT. Wayne, IN
    if thats not the problem check the waterpump... the pump has a small weep hole in the side facing the block.
    2003 Silverado LS 1500 Xcab 5.3 vortec 3.73 rear.
    2000 Artic White Buick Regal GS, 3.4 pulley, 3"dp, 13.81 @ 101 (sold)
    2002 Z28 Camaro, 1sc, a4, slp lid, headers, cb exhaust, 3.73
  1. Smell antifreeze at starup through a/c vents
    By mwolfe25 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 08-12-2010, 02:19 PM
  2. antifreeze leak?
    By dshewy14 in forum General Chevy & GM Tech Questions
    Last Post: 03-15-2010, 11:28 AM
  3. 350 antifreeze leakage
    By Aubio in forum General Chevy & GM Tech Questions
    Last Post: 02-08-2010, 08:25 PM
  4. Leaking Antifreeze
    By 913projectchevy in forum General Chevy & GM Tech Questions
    Last Post: 11-23-2009, 10:44 AM
  5. antifreeze leak
    By Brent0644 in forum General Chevy & GM Tech Questions
    Last Post: 10-24-2009, 09:14 PM
