    Master Mechanic CarpenterGuy's Avatar
    Jul 2008
    Leeds, Alabama
    Default Truck smokes at high speeds
    Hey y'all. My truck smokes when I floor it going down the interstate. When I floor it a little puff of black smoke shoots off. What's going on with that? Thanks!
    And if any of you could help with this, I'm working on my cousin's '97? Jetta and it wont turn over at all. We jumped it and while being jumped, the motor will crank up for about 1.5 seconds and then shut off. When we disconnect the jumper cables and try to crank it up it wont do anything..dead battery. Could the battery be the reason why the motor wont stay cranked? The car has also been sitting there for a year, but he swears he turned it on last week and ran it for about 20 seconds. Thanks again!
    2006 Silverado Z71 - 97,000 - totaled, RIP
    2006 Silverado Z71 - 122,000 (K&N 77 Series CAI, PowerAid TBS, Magnaflow dual rear exit, 33x12.50 Mickey Thompson MTZ, Tuff Country Torsion Keys, Tuff Country Add-A-Leafs)
    1966 C10 swb stepside (Gen I 350, Turbo 400 trans, dual cyl power brakes, front discs)
    I'll keep my money, guns, and freedom. You keep the Change.
    Inland Empire
    evening carpenterguy. the smoke doesnt concern me too much but it is a sign of extra unburned fuel passing through the converters (possibly and likely). it has likely been caused by a power adder like a modified fuel curve. as long as it doesnt have a check engine light and passes smog then no worries but it could shorten the life of the cats. If it will help you sleep at night then talk to you local mechanic about putting it on the scope (dyno with test equipment)
    As for the jetta, without looking at it, you are off to great start by suspecting the battery but the fact that it does it while being jumped would suggest something else. with out seeing the vehicle, knowing its condition, or hearing what it sounds like when cranking. Try pulling the spark plugs to see if it has hydro locked. If its clear then make sure that the key returns all the way to the off position before cranking again. by design vw will not crank more than once from the on position.
    Remember these are just tips there are plenty of other things it could be, let me know how it goes
    "if i had eight hours to chop down a tree, I would spend the first six sharpening the ax."-Abraham Lincoln
    Gary ASE certified master tech
    94 k1500 33" tires Hummer rims
    NINJA 600
    murdog94's Avatar
    Actually a little puff like that isnt anything to worry about, it is most likely carbon that is being "blown out" when you step on it. If you look at just about any vehicle going down the highway and look close when you hit a hill and their motors kick out of OD with the cruise on you will see it. A good seafoam treatment should alieviate that issue.
    Mike
    Currently
    2011 F-150 Crew 4X4
    Jul 2008
    Leeds, Alabama
    Alright, thanks! I will definitely seafoam it. I've never used it and I'm not too sure of how to use it, but I can figure it out. Thanks!
  1. Chevrolet : S-10 HIGH PERFORMANCE TRUCK
    Last Post: 08-02-2010, 06:40 PM
  2. Chevrolet : S-10 HIGH PERFORMANCE TRUCK
    Last Post: 07-23-2010, 08:00 AM
  3. My truck is Idling at high RPMs
    By gt1009 in forum General Chevy & GM Tech Questions
    Last Post: 05-30-2010, 10:17 PM
  4. 96 GMC Truck-Heater only blows on high
    By lilchicadees in forum General Chevy & GM Tech Questions
    Last Post: 03-12-2010, 07:44 PM
  5. Buying a high mileage truck
    By milligsc in forum General Chevy & GM Tech Questions
    Last Post: 01-14-2009, 12:04 AM
