    Default Really bad vibration
    I have an 06 extreme LT that has a really bad rattle between 2100-2400 rpm. It sounds like it is coming from the exhaust but i can not find from where. Just wondering if anybody has had the same problem and if yes what was the fix.
    I believe mine has the same problem.I posted something about it and a friend said it was the inside of the cat vibrating on its case.I was going to change it and never did.I don't believe it is the cat anymore.Mine is like a hum or a vvvVVVEERRRRt that can also be felt and when I got the truck it was only between 800-900 rpm...now it's 1000 rpm on the dot and again around 2100-2300.It also does it in park so it's not a drive thing.Does this sound like what you have?Maybe between the two of us we can figure it out.
    03 Chevy Silverado 1500 ext cab Z-71
    79 AMC Spirit GT
    77 Olds cutlass supreme
    Oct 2010
    Cobourg, Ontario, Canada
    Quote Originally Posted by 06extreme View Post
    --- check the heat sheild on top of the muffler / resonator / cat....at certain RPM's, the sheild/pipe section will flex / rise----you will need a helper to watch for rattles / noise as you slowly press the accelerator to find the rattle------you could also look for broken bolt head in the exhaust flange in the engine area---won't let go, but will rattle until rust eventually wins over ( from silverhobey)
    Quote Originally Posted by silverhobey View Post
    I forgot to mention that I didn't have anyone that would help me so one day I used my predator to set my idle right at 1000 rpm so the noise would be constant and I could investigate.As soon as I step out of the truck the noise is unhearable...I think something like the engine may be vibrating and for some reason something in the cab is actually making the noise because of it.Very weird and hard to find.Btw I can feel it in the steering wheel and if I look in my rear veiw mirror it looks like I have a subwoofer going.
    ok to kinda throw in a suggestion back to the cat. my dad had maybe a similar issue on his f150. while accelerating right at about 2000 rpms he would get a low grumble/howl and it was the cat.
    David
    1960 Land Rover Series II 88
    2001 Pontiac Sunfire
    NRA Life Member
    Jr. Engineer
    Z71_usmc_rebel's Avatar
    Jun 2008
    Beavercreek,OH (currently stationed in Jacksonville,NC)
    This could be a long shot for you, but may solve your problem. I thought I had the same issue sounded like a really loud metal on metal rattle from near the muffler. Come to find out the U-joints on the drive shaft were bad. Replaced those and never heard the noise again. If the problem hasn't been fixed may be worth taking a look at!
    Justin - Beavercreek,OH
    02 Z71 Ext. Cab (fully Loaded)
    * 9" Total Lift (RoughCountry)
    * 35' BF Goodrich Mud Terrain KM2s w/ 16" Chrome Pro Comp wheels
    * Hypertech Maxx Energy Programmer
    * K&N Intake
    * BlackOut Tails
  1. Vibration at low rpm
    By Z-71 in forum Chevy Silverado Forum (GMC Sierra)
    Last: 02-10-2012, 05:23 PM
  2. vibration over 35 mph
    By 88stepside in forum GM Powertrain
    Last: 11-29-2009, 12:44 PM
  3. Vibration?
    By CornhuskerChevy in forum Audio, Video & Gadget Tech
    Last: 08-09-2009, 09:35 PM
  4. vibration
    By jdog468 in forum General Chevy & GM Tech Questions
    Last: 02-26-2009, 10:08 AM
  5. Vibration
    By makthenif in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 12-19-2007, 07:17 PM
